i want an engine that works :bunny: i've seen that r35 around... getten more commen now so im not as enthouastic... as i know where another is garadged and i see it oftern :)
took my engine\gearbox out today.... i hate dogey people!!!!
Hey Jase, it's got a Kakimoto catback exhaust which was on it when i got it and i've ordered some HSD TT series coilovers which should be here in a couple of weeks, its the dark blue colour BP9 i think its called. I tried to attach some pics but my computer doesn't want to play the game so i'll try again later.
Cheers Daz.
