i have no idea some dude just said that could also cause my car to be reving poor
Perhaps check and make sure all your intake piping screws/bolts are tightened. I had a problem when someone I took my car too forget to tighten them up and so I drove off and it was trying to spool but wouldn't rev over 3000rpm. lol i was like wtf but soon worked it out!
how were you trying to spool, isnt yours n/a michelle?
but if there is any type of leaks around your piping clamps or split hoses the computer will sense it and run in a safe mode and wont let the engine rev. split piping or vaccum hose leaks somewhere can cause this type of problem.
well i went drifting last friday nite (31/7/09) at QR. it was awesome fun. the only thing i broke was my speedo cable. pretty stoked with how tough the car was. was wondering tho has anyone else from up here gone drifting down there. my clutch started to get smelly by the end of the night. was wondering what other guys use from up here. i dont wanna go a twin plate or a triple plate. i dont want something really dera either cause it gonna cop i thrashing all the time. any advice would be good
Don't try to drift with a Twin or even a Triple plate they're not suited for the application unless you're somehow pulling in over 600horsepower and you want a twin plate carbon clutch which wont have as much chatter as a normal twin plate.
Just buy a cheap exedy or china copy single.
ive had my twinnie for a bit over a year.
pretty streetable.
its been drifted and taken to constant track days.
still working as well as the day i got it.
keep in mind they come with a lightened flywheel. its a bitch to use in heavy traffic
keep your eyes peeled for a black ford falcon xr6 (looks to be the xr6T) ute.
its a cop car. pulled someone over near forest glen bp. lights are behind the grill, cant even see them
a the sphincter of the universe hit my car today in kennelworth... scared the shit outta my friend, window was half down so he almost got a face full of feathers! haha so funny. shoulda gone back to pick it up for dinner
Hs Ha now thats fast food for ya! lol
FG :blink: ?
i dont keep up with my fords haha.
its the model that came out after the BA, the new one.
Shud have had the window down mitch. Catch of the day.
Edited by r33cruiser
They're mostly targetting people speeding through the truck stop exit, trucks speeding and speeding by more than 20kph - I do security and that BP is one of our client so I've chatted to the guys driving the Ute a few times. Good guys.
    • Right, but that's in-cylinder, there's the interaction between that and the TWC which complicates things. Pulling out timing to reduce NOx is a strategy I saw in transitional emissions vehicles like stuff from 1974 or so. The two inlet runner system is interesting but I'm not sure it makes a huge difference as far as emissions goes, is it a tumble valve? I've seen stuff like that even in cars from the late 80s.
    • Hello all,   so i recently swapped out my rb20de neo with an rb25de neo( engine,transmission, wiring and the diff everything) but i just cant get the gear indication light on the dash to work when i switch to tiptronic mode. Note there is a steering wheel switch beside the shifter and i dont have that. I did notice yesterday while switching to tiptronic that the indicator on the dash started to work but it didn't afterwards. Does anyone know how this actually works? Or do i still need that steering wheel switch to be connected and on for that gear indicator to work?
    • Hence why I said earlier that I don't think the turbo Neos ever would have actually qualified as an LEV. I suspect the only actual LEVs that came out of Nissan were the NA Neos. Still call them all Neos. They all stil have the Neo-ness. Just that they don't all qualify as as LEVs.
    • It will give gains, but you wont hit 600 It will give gains but it wont get you to 600 imo. You will also sacrifice low down and you will be adding extra volume if you port match it, more so if you port the plenum runners depending and how its done I think the only time youre going to see about 100hp gains is if the car is making well over 1k kw I do have a spare set that I was going to test with, but i dont actually think there is anything worth getting going larger. I did a fair few S14/S15 and the standard TB is fairly small, I went to 60 and in some cases 64mm which is significant over the stock unit. You can also get some weird ratio changes. I think 20kw will be a stretch on a roller dyno. If I had it apart I might mill the shafts a little and not expect much, I think the stock size is still pretty good for a street/track car even with larger capacity. I might change diameter it if its a drag only car
    • Was going to say something about flog, wife, pilates, behind but I better not... No dishonour here
