im still droolen hahahah...
nah i gotta find out what is up with the turbo, still doesnt make anything more than 1 or 3 psi at max.. if anything at all.. after that. boost controler to 8psi and she'll be fine with a fuel pump.. then start on the inside mess.
till a tune
then 15psi daily and 19psi on high boost
till a tune
Checked your cat converter? It could be blocked,
I was boosting back to 3-4 psi barely until I realised I had blown my cat :)
brand new highflow cat... doesnt matter now
dump pipe came off last nite and boost spiked.... sent me a 180 into a rock wall and its f**ked.... bye bye r31 coupe *CRIES*
anyone wanna buy some parts off it.... kinda f**king devo'd
SSSSSSHHHHHHHHIIIIIIITTTTTTTTTT mate.
There goes 1+yrs of blood sweat and tears down the drain.
I can't believe it :D. Never thought you would smash a car.
Buy a cheap s13 shell and dump the box and motor into that :D
hey guys im from sunny coast and drivin a r31 nissan skyline wagon Gx 88 cream in colour wave if ya see me drivin through mdore. peace.
Lol did my partner open that gate on you and another blue r31 on maroochydore road? If so tidy 31 champ!
yeah it was a hot as f**k car.. i loved it, over 3 years of wadges and 2 cars got me there... till the dump pipe came off the turbo and boost spiked... hello wall..
cant think of another 31 atm... 4wd' to get, then i can get a track only car
welcome to the coast mate, prob seen my red now heap of scrap metal cruisen around? if you want some 31 parts hit me up, or
www.r31skylineclub.com will get you the into you need
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
