Last time I looked they did...did a really good job of binding up on the dipper at Bathurst and spearing them off in to the kitty litter
Sports cars are a nice handling over all package.....the viper is a large powerful engine attached to a chassis built manily around 2 bits of railway track
LOL RAILS...
did u see the lotus come over the peak too fast hit the strip and bounced off a wall and into the service road..??? 900kg 1.8L toyota engine ftw...the donut king cup thingo..
was a good race.. EVOS wer crazy.. and did u see the FD3S behind everything..?
FD3S are a sports car.. good overall package.. but they are kinda gutless.. like the RX8 bahaha... waste of engineering.
hi all,
im new to sau ive come over from the exa club as i had an exa now i have a skyline and am in desperate need of your help i have a r33 gtst series II 4 door auto yes i know its a friggin auto it sucks yadda yadda yadda anyways i got a bigger front mount a bigger turbo power fc and viper alarm system also window tint and pearled paint anyways i had a loose wastegate actuator and when i fixed it (as boost was coming on at like 5500rpm) it now gets full boost at 2000rpm the car is pinging like a bitch i cant afford to take it to a decent dyno and im looking for a stock ecu and decent boost controller to swap for it. i managed to get the car pinging not so much by self tuning as best i could but just want the stock computer and boost tap if anyone can help me out send me an email at [email protected] please cos im desperate to get my skyline working good btw i live in beenleigh but work at capalaba at bryan byrt ford >_< lol thanks guys.
The power fc needs to be modified to work on an auto car, you CANT run a power fc out of the box on an auto car. Yes it will work, no it won’t work right.
SydneyKid on these forums made a post in the tech sections explaining what needs to be changed to work, he runs one on his auto Stagea
hmm SK is smart.. hes a good bloke..
makes me wonder what he looks like..?? anyone got a picture of him im keen to see if he looks asian with white gray hair and long kung fu mostach
Power fc's dont run on auto cars...
This is true. I think his biggest problem will be with the Power FC.
My advice consist's of the following, seeing i owned a 4 door r33 auto at one stage.
1) Post in the WTB section of the SAU forums and let people know you need an R33 Series 2, Auto ECU.
2) Disconnect car battery and remove the Power FC ECU and hand controller (if it has one) and replace with your second hand r33 S2 Auto ECU.
3) If you already have a boost controller, i'd piss it off pretty quick and reconnect your boost lines into the stock boost solenoid to ensure either of the two items above arent causing the problem.
4) If the problem is still there and your running a stock ecu and boost solenoid, i would then locate another wastegate actuator and replace your current one. If your actuator is allowing your gate to open quickly, your turbo will spool around 8-12psi in an instant shot and give you a massive amount of boost spike.
However, you mentioned you had issues at 5,500rpm (Wastegate not opening soon enough), and now it spools to early (Power FC problem, Wastegate opening to early...Way to early...)
I'd seriously give the above a fair go.
Good luck. :rofl:
Chris
Edited by SunnyCoast
Welcome to the forum.
You said that you had a loose wastegate? how did you fix it? I'd be definitly pulling the power fc out like the others said as they obvously not suited for autos .If you cant pull the fc out for now take a few degrees out of the timing ( get one of your mechanics to do it, thats if you are desperate so it doesnt ping might, make the car not responsive). What fuel have you been putting into it ?Hopefully nothing under bp ultimate.I wouldnt be running any boost controller until your problem is fixed so get that wastgate sorted out or your chances of engine damage will be up there.
Good luck
Good luck
Ditto :D
    • You see R34 GTRs listed for 200-300k are they really selling for these prices? Kinda seems like the same ones listed all the time. Even with R33 GTSTs looking at gumtree. You have an auto with a bitsa interior for 35k. Another one needs an engine rebuild and asking 24k. And then you have a stock in better than average condition for 45k. Nobody is ever going to pay these prices.
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
