I live in rocky, it is not the most exciting place to live, and not much to do, but we do have 43 pubs all within a 15km radius :( You would prolly want to go to Yeppoon, I'll make an analagy:
Nambour = Rockhampton
Noosa = Yeppoon
Noosa = Yeppoon
ha ha michelle loves nambour! :)
but seriously what is any1 doing new years?? any1 else got anything exciting planned...
the novelty is starting to wear off for me, i dont think i will go out of my way to do anything this year.
cool, im thinking of quiting drinking. im a bit over it atm.
OMG really? I'm on my way to soberness too... only probably when I slip up I tend to accidently get plastered! Cant quite drink as much as I used to!
just got back from the whitsundays, golf buggys are fun!
damn id would hate to be you sam..... :P lucky bugger.
on another note check this website out, some lady has started on the coast here about hoons, post up videos and stories of hoons on the coast.
http://www.dobinadope.com
ppl have started spamming it already lol
Edited by 85URK
damn id would hate to be you sam..... :happy: lucky bugger.
http://wwwdobinadope.com
Is that the right link?
www.
Edited by Baysidebluebnr34
some mates of mine saw nismo boy on wednesday at one of the round-abouts near noosa. they were down there with some mates. there was some black 180sx's (my mates) a young dude in a 32, a guy in a ed falcon and a few others.
the 2 guys in the black 180's are my mates. the guy that had his missus with him, that was her car.
the other guy ended up hitting a sign post with the rear quarter while taking evasive action when someone lost it in front of him.
i wished i had gone down. sounded like a good night.
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
