Yeah would love to see member "Sunnycoast" R34 in person looks nice, and i havn't managed to see it around the coast so i'am not sure where you guys normally go cruising. Anyway work is calling seeya's around.
yea i know wat u mean...hopefully the skyline wannabe's will get over them selves and find something else better to do than start sh!t with others.
skyline wannabe's BAHAHAH. ive owned my fair share of skylines. the only skylines that look half decent are 32 gtrs, 34 4 doors and ofcourse the 34 gtr :P
My point is that this is a skyline forum not a 180sx or other cars. and thats ur opinion of skylines, i personally think 32's arent as nice looking as 33 or 34's.
Anyone heading out this sarvo? I'll be out in my blue 32!.. There's so many skylines on the coast now I dont know who anyone is anymore! When i first bought my r33 gts-t there was 4 on the whole coast, now there's gotta be 40, hell there's 2 r33's that live in my street alone! But saying that i'd rather see 40 R33's any day than 40 bogandores of falcraps.. If anyone seem's a a blue r3 gt-r gimmie a wave!
Cheers, mat.
i now have 2 SRs in my garage.. a CA on the floor and a RB25neo in a wreck down in the bottom garage :P
SR POWAH
2 180sx for me... drift/street 1997 type x 2way teins 160kw gauges raskit lots of bracing and street/drift 1992 SR 180 with fmic and exhaust std everything else lol...
both getting skyrine brakes in the next month.. and the type x gets 240rwkw before christmas. :P which will smoke a skyline with 300kw.
R34 GTT for the type x and R33 GTST for the 92 model the 1992 180 will get a RB25neo early next year and should hit up 200kw :(
go the 1220kg 180sx!!!!
u skyrines boys have no idea on how much weight ur pulling. gosh even m old gtr was heavy.
Mark bring your 240rwkw along when you have it and I will personaly kick your ass so you will shut up ha ha
SR POWAH
R34 GTT for the type x and R33 GTST for the 92 model the 1992 180 will get a RB25neo early next year and should hit up 200kw :)
Why compare oranges with apples? Though I see you are using skyline parts as *upgrades* on your cars :( ... has ns shut down or something?
And since I am bored today Marki here is some maths for you
a 300rwkw r33 GTST gives a rwhp to pounds ratio of 0.1346
a 240rwkw s13 gives a rwhp to punds ratio of 0.1197 which is signficantly slower
to give a s13 a similar power to weight it would actualy need 270rwkw giving a rwhp to pound ratio of 0.1346
oh and my 300rwkw skyline has a rwhp to pounds ratio of 0.146
maths is not your friend Marky
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
