Do you have to provide your own helmet or do they have ones u can 'rent' out? also what would classify as a non approved helmet?
you have to take your own helmet. Has to be basically adr approved,they should have a sticker saying that, also if a helmat is damaged in anyway like cracked they wont allow it.
ah serious.. how bout i just say i personally prefer the silvia engine and chassis to the skyline so ill leave it at that...
yeah good descrete place aye andy if u need a hand let me knw.
u gonna run a sandwhich plate or a sensor off ur cooler.?
it has a sandwich plate with 2 sensor holes in it :(
Why dont we all organise a meet up sometime, have a bbq, few drinks and get to know eachother?
Seems alot better than having a dig at eachother on this forum....
Anyone?
i suggested this ages ago , well about 4pages.Im in!!
really..?
still waiting for the specs to back urself up.?
log off please key board warrior
anyway speaking of mounting boost gauges in skylines.. this is what i did in my old GTR. fits nicely... being a smoked gauge its very descrete but when ignition was on looked hella good.
Thicker than a brick shit house aren't you. You just don't get the point, for the third time, i'm happy to continue this conversation in a thread thats not in the sunshine coast section. Is that to hard for you to understand? Start a thread, or pm me. Simple as that.
lol who r u anyway.. obviously a major player on the northern beaches..?? well excuse me MR high roller.. :sorcerer:
i just found a new play toy..
ahh performance wise.. u wer saying it was a shit kit before wat was bad about it..?? was it just cause u got a 25t?
you know how the rb25 has the stock oil cooler thing and the rb20 doesnt? i think that was the problem as the lines could not connect to the sandwich plate cause it was too close to the chassis rail
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
