lol who r u anyway.. obviously a major player on the northern beaches..?? well excuse me MR high roller.. :sorcerer:
i just found a new play toy..
Yeah thats it mate, i'm a high roller, yep, you're 14? Have you started that thread yet mate, or have your balls not dropped?
RB25DET, 295nm @ 4800rpm from factory. NEO RB25DET 343nm @ 3200rpm. Wow i'm right, but we new that all along. FACTS tell no lies. -> http://www.importforums.com/carsinfo.htm
Edited by Dynamix
its a boost gauge mate, if ur scared taht cops are goin to rade u about a boost gauge u aint goin to get far on the mod list...ive got 4 60mm DEFI guages sitting on my dash. Id rather cops look at my interior then under my bonnet :cheers:
Yes indeed. cops dont look for small things like boost gauges, besides if they are mounted and fitted properly theres not much they can do about them.
i dont know about that, we all know wat they are like, have nothing better to do but pick on us that have nicer cars than them. ARRRH Stupid Stupid cops. i guess they need to find some way for us to pay for their doughnuts
i dont thinks its matter that we have nicer cars than them, i could go on all night about this but im not in the mood for rambling on.I have never known anyone to be pulled over for a boost gauge, its usually for other things, eg exhaust, low vehcile. Keep it simple and not too noticable if you are that worried about it.
yea i know...im just pissed off at them haha, then again who isnt. but fair enough to say they pick on us cause they havent got anything else better to do.
yeah well thats debateable depending on who you speak to, it not that they have anything else to do but they have been told to go out and do it.18 months ago i was pulled up for not doing anything but driving to amates place and the the police notice that i had a larger than normal ( meh define normal) exhaust tip so then they proceeded to follow me to the cop shop where the task force was set up did me for 5 things,but that was there job purely to go over modified cars left right and centre.
and the funny thing was i ran into my mate who was also getting done.
:cheers: did u buy a specified drift rc? i just purchased the NOVAK GTB 3.5r...quickest electric motor made for rc cars to this present day. cant wait to get it. might do some other mods like fmic, .04 inch xhaust all the way through then may think of doin other mods like turbo charging. ill race ya sr power...dont be fooled by its small size...then again doesnt take much to beat a car with an SR engine in it... Edited by Darkness_Ryda1
Dou you have a problem with yours counting up excessively all the time? If i drive on the highway it counts up to like 9 minutes all the time
yes mine does that aswell when its on auto mode, i cant seem to get mine to move to the other functions, its wierd, dunno if there is somethign wrong with it or not.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
