Hey guys, im trying to diagonse a problem im having with my R34 GTT.
I just changed from lowered spring on KYB shocks, to a set of HKS Hypermax coilovers.
Got one problem tho, the wheel on the drivers side scrubs hardcore when turning !!! But the left one doesnt. The car is low, and ive never had this problem with lowered cars before, however comparing left and right wheels on flat surface, it appears as if the passanger side has more neg camber than the drivers side. Its only on the drivers side when cornering harder you notice the scrub noise. After inspection, it apprears to scrub on the outter gaurd arch :laugh:
It didnt do this prior to the coilovers, however with coilovers in, it scrubs :P
Im frustrated, so can someone please shed some light would be appreciative :D
Edited by Mr_G
https://www.sau.com.au/forums/topic/140687-wheel-scrub-one-side/
Will measure it up tomorrow :laugh: Im pretty sure they are equal , but ill measure it in the morning.
Im pretty sure its the camber that is making it scrub, as there is more negative on the passanger wheel, rather than the drivers side wheel, causing it to scrub, however i never really turned a corner on the passanger side yet, which i might try tomorro morning aswell
  • 3 years later...
Sorry to dig up this VERY old thread but thought it'll be better than creating 1.
I'm sort of having the same problem (scrubbing on the driver's side front) but its in the front middle wheel arch. Because its scrubbing the front, I'm thinking it's the castor adjustment. The scrub is very obvious when doing a full lock right turn.
What would be the solution to this? If the other side doesnt scrub, doesnt that mean you can adjust the factory castor/camber settings to suit instead of doing more mods to make it suit? Who would be doing settings like this? Would a wheel alignment/balancing fix the issue?
For the information, the car is a 33gtr v-spec with Tein super street coilovers without any other suspension mods. The wheels are 18x9.5 +15 with 285/30/18 tyres.
i rkn your tyres are the problem 285 is freakin massive try a 265 which will be more than ample on 9.5" should be sweet.
do u know what its hitting exactly?
Too lazy to go out and take a photo but try imagining the driver's sider wheel instead of the passenger. On full lock right the circle part (middle back of inner guards) is where its scrubbing.
if it isn't scrubbing at the front adj castor rods will fix it.
if you have adj castor rods and still cant get rid of the scrubbing or it scrubs front & rear, you've fiddled with the height, your only other option is to go a smaller tyre, or wheel with less offset.
g/l.. :blush:
Yea I know adjustable castor/rod or bushes will fix the issue but I'm hoping not to do any more mods to the car. We'll see how it goes as its not really that bad (only scrub when I full lock hard and road is uneven).
well we're pretty limited they hey.. if you dont want to do any further mods every piece of suspension on the front will have a a bee's dick's worth of adjustment between it and the next.. loosen each part and tighten it so its favouring not scrubbing.
its a similar case on gtrs with turbos between head-manifolds-turbos-dump pipes-front pipes
Negative reading on camber means the top of the wheel is leaning toward the center of the car (tilted in). The passenger side is more negative means it's leaning toward the center more. If the caster is even, then the car pull a little to the left, and you probably won't even feel it.
The caster settings usually responsible for pulls, car will pull to the side with less positive caster, but around 1/2 degree more positive on right is preferred to compensate the crown of the road.
Driving Lessons Glasgow | Driving Lessons
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
