Wondering what people have to say about 17" tyres for Skylines ?? (for normal street use)
Which Brand ?
Which type/model ?
What profile ?
How Wide ?
What cost ?
How long they last (typically)
Where is the best (cheapest) place to buy ?
Cheers,
BF
https://www.sau.com.au/forums/topic/1407-tyres-what-do-people-use/
i havnt got the 17's but ive got the 16's version..
the tire ive found to be the best bang for bux is the dunlop fm901, yes thye also come in 17's as ONARUN also has em.. i got my 16's for about 190bux.. so 17's shouldnt be all that more..
and i wont give u an idication on how long they last.. as my driving wont give a good indication in regards to tire ware:D
there awesome things.. and very well priced..
i have ultra radials
17"x9" 235 45's on all corners
$205 a tyre there really hardie as they still look brand new and i've done 60,000km on them only about 3% where to the tread depth.
the only problem they are really hard compound and are extremely slippery in the wet.
FM901's don't last long as they are made of a soft compound. they are very grippy so good for trackwork and excellent for road use. they like to bite the road and then let go all of a sudden. you don't get the screeching indication before they let go like other tyres. if you want something that will last you look for a harder compound than that of the 901's.
To contradict Porgie in the above post I would have to say that the Dunlop FM901's wear quite well.
I've got them in 235/45 17 and 255/40 17. Put them on the car in March for $1240 fitted and ballanced.
They are a bit noisy (road rumble), but never squeal and I was very happy with the communication and grip at Eastern Creek and Wakefield.
Apart from one of the rears de-laminating after about 400 km :eek: (Dunlop replaced it without too much fuss at no charge) I am happy with them.
I'm running Yoko's a-spec. You can' buy them at normal tyre places as they aren't DOT approved. But hell they grip very well. I've got 255/40/17 all round on mine. Paid about 280 a piece at Eagle tyres in Granville. Considering I'm quite aggressive on the track, they seem to be doing the job very well.
Fatz has e-specs, and they look evil. I might try to source them next.
what's de-laminating?
my driving has seen them wear out quickly and the fact that they are a soft compound indicates a shorter life
Yo George
Deliminating is when the rubber starts to pull away from the carcass.
Andrew
Falken Ziex's on mine, on standard rims....Very happy with the grip, I can't wait till I get 17's thou......Might try some new rubber, whats Falkens high line tyre called ? GRB ? What are they like ?
Andrew
the carcass is a cavans type material, probably canvass which nthe rubber is attached to. I'm using my knowledge of kart tyres here...they don't have steel belts, i think the steel belt is either in the rubber or wound into the canvass....
    • It's kind of interesting - They definitely do builds that split the difference between what they like and what will generate views and engagement. The NC Platform always surprises everyone in a good way, in an uncomfortably good way some may say. They could throw a LS in there and arguably have the best (and best performing) car of the entire stable. But that isn't necessarily what draws views, because people viewing don't want to accept the vegetables of a LS NC MX5 being a superior vehicle in every way (including fun) than a RB26 240Z. This is also why there's not a lot of content about the GR Yaris (on the web in general). They're too good, yet 'only a Yaris' The community doesn't want certain cars to be as good as they are - to beat their hero cars, and I believe the NC MX5 is absolutely one of those cars.
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
