Hi All,
You've probably read my other stupid post about me hooking up the fuel lines backwards and "thinking" that the place who cleaned my injectors fried them.... Anyhow I've assembled the fuel rail, plenum, throttle body with new seals and gaskets... And the car starts.
The Good News
I've noticed it starts easier, plus idles much nicer with no idle hunting and also the motor is heaps more quiet.
The Bad News
Feels like the car is 2x slower than before, I can't feel the kick when the boost hits. I've checked for leaky vaccuum lines & other air lines that go to the AAC, etc... no leaks... and the boost still registers 12PSI..
What is going on?
So in your opinion, you think it's running more rich?
that is fairly common from what i have seen , that cleaning your injectors allows them to flow more ..
flowing more for any given pulse of the injectors would mean that more fuel per pulse, which would be more rich, as the ECU doesnt know how much its flowing, only how long its pulse is.
so yes, it would be running more rich
I'd say get some management as Chris said :laugh:
You've hd it running leaner than normal... now its just running as normal and needs to be leaned out again in the correct fashion.
See how it goes after that... shouldnt be an issue i reckon
But leaning out is asking for trouble right?
Well I might get a re-map done again on my ECU and see how I go from there....
just get a quick recheck of the AFR's ona dyno
if they are good now, means they were bad before.
You probably should reset your ECU after cleaning the injectors so it can re-learn the set up. It can take a couple hundred kays to settle in.
Also it could be that you were actually running closer to normal AFR's because the injectors were dirty. The actual reason could be that the O2 sensor is kaput & the system is running over rich because of it.
Look for lots of black crap on the bumper around the exhaust after a weeks worth of driving, a good indication it's over-rich.
Edited by JazzaR33
It's not running rich, my bumper isn't that dirty...
I think what Craved said was correct, because my injectors were so dirty the car was leaning out hence giving out more power...
I'll throw is on the dyno when I got money, so broke now
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
