Hi everyone, Just a few questions about oil preassure:
I have a R32 GTR and when im driving along the oil preassure sometimes sits bellow the quater mark when not under heavy load - is this a problem? It generally only happens when im just granny-driving the car about and a good free-rev will generally increase the oil preassure - when giving it a bit more stick (still keeping to within the legal limits of the road of course) the oil preassure usually jumps up a fair bit, between just above the quater mark or just above the half mark, however I have seen it go higher.
if giving it decent stick it will normally stick on the 4 (halfway) mark.
What does this all mean and is it bad?
The car just got back from a major service at GT auto and they didnt say anything about it. Am I just being an old worrysome grandmother?
Thanks
Ian
https://www.sau.com.au/forums/topic/140746-oil-preassure-questions/
theres no such thing as being a worrysome grandmother when it comes to oil pressure.
get it tested by a mechanic who has a manual oil pressure tester asap. it should be at least past the 6bar mark under load.
if it all checks out ok, then replace your oil pressure sender unit.
what oil are you using? thin oil tends to read lower oil pressure.
Im using motul 4100
Is there anything I should be looking out for in particular to indicate that the engine is not getting enough oil? in my last car tappit noises were a sure sign of this.
//edit just reading a another thread about an extra litre of oil... would this be a good idea as a stop-gap until I can get it tested?
Edited by IanB
More info:
On cold-start oil preassure is fine - it doesnt really dip down low until the oil gets hot - even then its only low during idle, sits just bellow the 2 mark on the gauge. Once you get going again it comes back up to anywhere between 1/3rd or 2/3rd's.
Will have it checked on monday however
Driving the car around tonight it was alot better, it sat more or less on the 4 (halfway) mark everywhere I went so I decided to give it some stick, I did notice on WOT it was blowing a fair bit of smoke, but this was only in the higher RPM range (6.5k +) and none at all in just normal driving...
I will take the FMIC pipe off tomorrow and see if theres any oil in there. Should I take it off at the engine side or on the intake side of the intercooler? Additionally, will there be any oil leaking under the car anywhere if it is a turbo seal?
I have put a sheet down under the car tonight to check for drops.
oil seals can be bloody expensive, after buying the car 2 weeks ago I have allready spent alot on it in just maintaince (1.5k so far) so im really hoping its just me being a worrysome grandmother. The car was much better tonight driving it around in all conditions, under heavy and light load and at idle the oil preassures were comperable to my mates R33 GTST.
A bit of smoke is normal for a turbo car on WOT in high RPM is it not?
Or is that just wishful thinking on my behalf?
//edit on closer inspection of the manual there it says at idle there should be 1.5 kg per cm squared, 3 at 2000 RPM and 4.6 at 6000 RPM which, if it translates directly to what the gauge reads (eg 1:1) then thats exactly what my car is doing.
Edited by IanB
How are you seeing the smoke? Revision mirror?
I know at night I can see a cloud of something from mine once it comes on boost.. Especially if theirs headlights behind.
I've sat behind mine with the other half driving, interestingly I can't actually see anything apart from the a little bit of over fuelling.
yeah im thinking it was just overfueling on the ECU's behalf, the engine sounds, boosts and runs smooth as a babies bottom.
Still, as has been said, one can never be too careful. That being said, I just had a major service less then a week ago and GT Auto has a good rep (they mostly deal with high preformance imports, there were 6 - 8 other skylines in their yard when I got there and another one on the dyno being tuned along with some stageias and a XR6T) and I doubt theyd miss something so critical as oil preassure, however I will certainly ask them what they did to make sure that it was a-ok.
And yeah cubes, it was in the rear vission mirror with headlights behind me, looked like a smoky tailwind - prehaps the GTR was just ripping up the dust on the road? :laugh:
Edited by IanB
Overfueling... Just because there's a little haze of black it doesn't mean its running rich.
Mines been tuned to a 12:1 afr and I can see an ever so slight haze.
To see this completely ignore the night time revision check as it really shows it up badly.
Get some one else (the other half) to drive the car with you in pursuit.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
