Hey all.
Ive got a 94 gts-t, if I try boosting it over 10-11psi it starts to missfire in a pretty harsh way...
Anyway I took it to Gavinwoods autotech (some of u qld'ers may know him) and he came to the conclusion its a problem with the coil pack. I cant remember now wether he said it was just 1 coil, or the whole lot needed replacing. anyway he ended up changing the plugs and setting the gap etc on em, and didnt really want much more to do with it.
My question who/how can test which one it is, and is it ok to just replace the 1 faulty coil? i was told coils are around $200 EACH! new from nissan (which I aint planning on paying that much) or around $90 if im lucky enough to find them second hand.
The next mod im looking at is a new ballbearing turbo, so I would like to get this sorted before I purchase a turbo and am stuck with 10psi instead of 18 or so :)
and I have a fmic along with other mods so it can handle 10+ psi easily...
https://www.sau.com.au/forums/topic/14075-coil-pack-problems-on-my-r33/
try searching these forums first...
it is a common problem with R33's because of the ignition maps on the standard ECU. I seriously doubt it is one of your coil packs, as it would always happen, not just when you boost past 10psi.
Only cures I know of are:
- Aftermarket ECU
- Piggyback ITC for ECU
- Advance timing past 20 degrees (although could be dangerous)
Exactly right...its the spark plugs, get some .7mm gapped plugs...my friend spent BIG $$$ and it ended up being the plugs, its like Popping sound with more than 11psi. He changed plugs and now its gone...
Get some good platniums or iridium IRIWAY, pm me if ur want heat range 7,8,9 or 10 (true racing plugs, which no one will stock, except performance places. about $28.00 each but more than perfect and last 80-150,000km)
what kinda power figures r u looking at?
A heat range of 8 seems very cold to me.
Let me put it this way, I have a turbo back xorst, filter, and boost controller (set to 11psi), and I am using a heat range of 5!
I was using 7, and they would foul very quickly, and within 2 weeks of installing/cleaning, the problem would return.
I used 6, and it was much better, but still happened if I didnt thrash it once in a while.
I am using 5 now, and initially it was much better, the car was purring like a kitten, but if I have been giving it heaps, I notice a little pinging.
So a heat rating of 8, is overkill with only basic mods, and only makes your problem worse. (assuming you only have basic mods that is)
And, go the coppers next time, they produce a better spark, but dont last as long.
NGK BCPR6E is the best plug I've used so far (and yes I have used platinum plugs too)
Do a search, I'm sure some people are really sick of me talking about spark plugs :D, as this has been brought up before lots of times, you will find some other useful info too.
George
Well most of us have had this problem, and the way I solved it was:
- NGK BCPR(5/6)E plugs at 0.7 mm (better 6)
- take car for 15 min drive to warm it up
- Reset ECU
- advance timing to 20-23 degrees (careful though this is done properly to avoid pinging)
- Take car for a good thrashing (if it pings, then re-do your timing - retard it)
My car has the same problem. It is setting at 0.7bar now. Anything more than that will have popping sound/ misfire.
I have already re-gap my spark plugs to 0.8mm from 1.1mm. And they are platinum plugs. (before re-gap them, I can't boost anything over 0.5bar (stock boost I think)
Will the after-market computer solve this problem. I want to boost it to 0.8 or 0.85 bar and should get better fuel economy by the new computer.
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
