Have you guys got a boost cut defender or aftermarket ecu? as the stock ecu will cut ignition at about 12psi.
Just a thought, it might be boost cut.
I am running NGK BCPR6ES (pre gapped at 0.8mm) with 200 odd rwkw and I can just keep winding the boost up (most I have used is 1 bar - its a stock turbo) but haven't had a problem.
Heres how i would go about it.
1 set boost to 11psi or lower if the problem exists at that boost
2 Have my new plugs gapped to .6 or so
3 Take kick panel off to expose the computer and check wiring for loose connections
4 Unclip Ignighter pack for a known good one and take the car for a run
5 Take 1 known good coil pack and give it a run each time swapping good coil pack to a different cylinder
6 Replace computer with known good one
Ive done this from easiest to hardest labour wise..
Ecept the computer as it is rare for it to happen plus availability of a spare is sometimes difficult.
Good luck mate
OK....Gave the car I run today....running at .8 BAR the car started misfiring at aroung 5000RPM...
I had a look at the S-AFC and noticed that all the settings were set to zero. I re-entered the correct settings but unfortunitly the misfiring still occured but now it starts to misfire at lower revs...
  • 1 year later...
i had this problem with my 33........turned out to be standard fuel regulator. i got a malpassi and everythings sweet........to test coils pull em out and take to auto electrician...they should have an ohms reader to test the resistance......
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
