Hey every1
just asking wether i need any other upgrades if installing tomei camshafts in... the ones from just jap?
im kinda juggling between them or other mods, :)
how much gains would u get from them, i have a r33 series 1, large blitz fmic, 3.5 cat back, custom cai, custom manifold and soon customs front.dump pipes.....running on 12.psi :)
is it possible to just get the camshafts without altering the springs or valves???????
and how much would it cost for the install roughly :)
thanks guys
https://www.sau.com.au/forums/topic/140784-camshafts/
Hey,
Cams are good, especially poncams which do not need heavier spring, valves, or having an aftermarket computer in.The Poncams are designed to bolt on and drive off...not even cam gears are needed.0 adjustment works the best for them.
If this is the only modification you are planning in the next year or so ...do it because you will get great results.
Hope I have been of some help..
Cheers :sick:
These cams are around $800 for the set and installation should be around $400.
Your power output will increase slightly, but your response and power curve will be alot better.
https://www.sau.com.au/forums/topic/140784-camshafts/#findComment-2624189
700HP-GTR33...great to see you posting and getting involved in the forum...but
You wont get any real gain if your still running the std turbo...and anything that changes the breathing of the engine as dramatically as cams means you need to tweak the fuel and ignition maps of the engine as well.
Look at the results of Bass Junky, cams proved to be a wast of money with std turbo, he even had management which was tweaked to try and get a gain with the cams. If you do a search i think you will find that ppl are yet to get any gains from cams on std turbo. On an R33 the best thing is an exhaust cam gear....a thread by benm and his old R33 comes to mind. The quikest std turbo / ECU R33 i have ever been in so exhaust cam gear gets my vote for a lot less money
https://www.sau.com.au/forums/topic/140784-camshafts/#findComment-2625221
on a standard R33 GTST (that is standard ECU and turbo) you will not get any real gain from just bolting in a set of poncams. the stage you are at now, your stock cams are best. maybe consider an adjustable pulley for the exhaust cam. you should be able to get some gain there.
https://www.sau.com.au/forums/topic/140784-camshafts/#findComment-2625238
The fuel and ignition maps need a rework, so you need a power FC or something similar. They do not work like standard in the low rpm and idle area in terms of mixture.
Gaskets/seals for the top where the cams live.
You will also need a set of new retaining studs as the old ones may break either down the track of when re-torquing them.
You would do well to obtain cam gears at the same time as mentioned too.
What tomei cams do you plan to buy and why?
Edited by rev210
https://www.sau.com.au/forums/topic/140784-camshafts/#findComment-2625244
yes, the increase that can be received by putting cams in, can be resulted by a computer and tune alone. i mean a computer is an upgrade that has to be done along the way and most ppl see it as one of the last mods you do to your car. i mean this guy hasnt even got a fuel pump so putting cams in shouldnt be on his prioritys right now.
https://www.sau.com.au/forums/topic/140784-camshafts/#findComment-2625331
Roy is correct.
ECU or piggyback should be your next upgrade I just had an exhaust cam gear installed on my car while it was getting its 100k service. Gained 5rwkw which the tuner said they usually get with the stock turbo.
Only cost me $90 a good mod to do when your getting this service done. Look the groupbuy section of you want to get one
cheers
https://www.sau.com.au/forums/topic/140784-camshafts/#findComment-2625472
there is a small gain to be had on a stock turbo RB25...
I have made 208rwkw with SAFC, EBC, exhaust (stock dump) and FMIC at 10psi WITH Tomei 256 degree poncams...
even taking into account a 'happy dyno' there is an argument that they will give you some kw's at the top end and help it make power all the way to redline and not taper off at 6,000
dyno chart is attached, you be the judge but I think they are great
BTW they are set at 0 degrees and work with the stock springs and VVt
https://www.sau.com.au/forums/topic/140784-camshafts/#findComment-2625799
A mild set of cams allow the same power to be produced earlier in the rev range, with less boost required to achieve it.
But if you are planning on sticking with the std turbo....i would be very interested to see an engine that actually has more mid out of it. Does anyon ehave graphs of before and after?
Even with NickR33s results...im not convinced. The std turbo isnt that big for a 2.5L and i doubt they can provide the airflow to really need cams to help fill the lungs.
If NickR33 picked up some grunt...i woudl then ask did he have the SAFC tuned before the cams were installed?
Not being argumentative, just curious to see if we can rule out some other things :P
https://www.sau.com.au/forums/topic/140784-camshafts/#findComment-2626808
look I can't give a before and after so I am would be lying if I said I have any concrete proof... however I do seem to make the power at relatively low boost as rev210 would suggest
I had the SAFC in and tuned before the cams so no help there and I cannot be sure I picked up ANY power... however the last dyno tune before the cams was also pre FMIC and it made 170rwkws's... the cams and FMIC were added and SAFC tuned again (to pull even more fuel out) and I got 208rwkw... different dynos, different days
I just wish the tuner had done the before graph as I had wished
BTW the cams were always planned to go along with a turbo upgrade, was just curious to see what would happen if I did it the other way around
https://www.sau.com.au/forums/topic/140784-camshafts/#findComment-2626947
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
