Im 6"4 and not the skinniest of people, what aftermarket seats could I get for an r32 to give me a lower seating position and more leg room under the wheel.
I could also change the wheel to something a little smaller but I think fixing the driving position to give me more room would be a better option in the longrun.
https://www.sau.com.au/forums/topic/140822-r32-tight-fit-change-seats-or-wheel/
Basically any seat with a 'low' rail will do. e.g. any recaro or bride etc.
you'll be suprised, but a slightly smaller aftermarket wheel can give you a lot more room. and then you don't run into the toruble of running aftermarket seats - potential defect etc.
hey dude i have the same problem and im only 6'2"... i have a momo steering wheel that is heaps small but it doesnt help that much on a long drive. A rather large mate i have used to own a 32 and he said he put gtr seats in and you sit lower in them, so keep your eye out...
yes the GTR seats sit you quite a bit lower than the GTST seats. also to give yourself more leg/knee room try a smaller wheel (340mm would be ideal) and a spacer to bring the wheel closer to you.
Make sure you try the seats before you buy them, as many of the jap seats are very skinny.
Some of them (i think Bride do at least) have two different seat widths, so us Aussies and Americans can fit our fat arses in them.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
