Hey guys ran into a problem, its time for my gearbox oil to be changed and who ever owned this before i did has put some type of synthetic oil in it, its bright blue .. yes thats right hahah nar its not the funny when you think about it.
Well does anyone know what type of oil this maybe? because if i run a diffrent oil now it will kill my gearbox.
Anyone seen this oil before???
https://www.sau.com.au/forums/topic/140875-what-the-hell-is-this~~/
are you lookin to use the same oil? i doubt you will kill your box if you put a different oil in it. ring a trans specialist and ask what type of oil they'd recomend. redlines seems to be pretty good.
and dont redline oils come in weird colours like that?
Dont normally work on cars like this im abit new to all this stuff but as a rule if you use the wrong gearbox oil you do destroy them its sunday btw =D just seeing if anyone knew i will be ringing tomorrow.
Penrite Lim slip Diff oil is blue, but im just shit stirring you that it would be that, unless some muzza owned the car before you. lol
Im agreeing its some exotic expensive oil, I thought shock proof was red....lol cant remember
don't mean to hijack this thread but when do u change gbox oils? and where do u put them in?
Do a search....D.I.Y.......it will show you the two bolts you need to unscrew.
:sick:
The oil is lighweight-shockproof and available through Bursons and is about $110 dollars...each store has a different price.(?)
At least this is what I found out when calling a few up in my area.
Fill it up until it overflows......
What problem are you having anyway because normally this oil is used when you are having some problems.
It might be a waste of time ...especially if you need to over-haul the unit.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
