Hi,
I'll be frank and say this not for an RB series motor, but rather an SR20DET...I have gotten it tuned recently to the current power level however I have a problem with the power band dropping off too much at high RPM...
The current specs for the head are as follows:
Solid lifter conversion - so the ramp rate of the cams are different to the hydrolic type cams..
hks step 3 264 inlet cam
hks step 3 272 exhaust cam
1mm oversized exhaust valves
HKS valve springs - coil bind is not an issue - its been checked and came up good
The turbo is a modified Apexi RX6 unit with a bigger compressor wheel, .80 A/R exhaust turbine with 67mm exhaust wheel...so it should not be dopping off boost or power top end wise...
Now the cam gears are currently set on 4 deg advanced on the inlet and 3 deg retard on the exhaust, i just took pretty much a stab in the dark with these settings...
The boost controller is an AVCR and I have no idea why the boost curve looks like that... :S
With this current power i ran a 13.1@125mph recently at willowbank with a 2.5 60 foot... :S
What would you guys recommend i change the cam gears to to get my power curve to keep on keepin' on...
Here is the dyno printout:
Edited by TurbostyleR
https://www.sau.com.au/forums/topic/140888-cam-gear-problem-dyno-graph-inside/
hey there mate, your boost control has too much sensitivity setting I'd say. Sort that out first as Nismoid suggested. The upper power drop off you see there seems to be fairly typical with the SR20, at least the ones I've seen/tuned on the dyno. Cam lobe center angle seems to be the key with any cam gear tuning.
The tighter the lobe center the better higher RPM flow & therfore torque will be.
Unless you time the cam gears to the crank so you know the lobe center angle to start with, any changes will be a try it and see whats happens affair.
Also can you post your dyno graph showing the torque please as this can be more helpful to see what is going on in the engine and its peak efficency point.
Hope this helps,
Mike
Edited by The Alchemist
Thanks Mike for your comment, much appreciated.
The boost controll issue is going to be taken care off with a bigger wastegate spring as the current one is too small and the avcr duty cycle is pretty much on the limit of where it should be.
I dont have any graphs showing torque unfortunately.
In regards to "tighter the lobe center the better higher RPM flow & therfore torque will be" What do you mean by tight, i dont understand all this lobe center stuff... :S
need a diagram really to properly explain, if you do a search for Cams + "lobe center" on google you will find many sites showing a couple of cams set up with a circle 360 degrees around it and a centerline drawen down the middle of each cam lobe 2 the center of the circle. The angle between the lobe centers becomes an obvious thing.
The smaller (tighter) the angle is the more the cylinder head will tend to flow better at higher RPM. Its to do with the decrease in time allowed for air to pass through the head as RPM increases you see.
This increases the overlap (the time the inlet and exh valve are open for at the same time) which allows more air at higher RPM to pass thru the head. Complicated eh :) Anyway, small changes of a degree or 2 can have a substantial effect on the way the engine produces it torque and where it produces its torque. Using factory cam settings as per the timing marks with adj wheels on zero zero, the lobe centers tend to be too wide at say 114 degrees which is why you read about everyone adv the inlet and ret the exh which tightens the lobe centers and improves turbo response and overall torque. A good thing. The problem is that the other important cam setting is the overall relationship between the cams and the crank. Once you get the best lobe center angle you can move on to the adjusting the inl & exh cam together either advancing or retarding them. This moves the torque curve up the rpm or down the rpm range. All fine tuning but all worth it in the long run. Don't get to keen on the light and mid load tuning either cos this all changes when you change the cam timing and often has to be done again
Mike
Thanks Mike for the explanation I really appreciate it!
I dont think it was losing traction on the dyno, but its a good point, I will put it on another dyno and see if it does the same thing..
On a sidenote I took it to the track tonight as is and reeled off an [email protected] think that dyno reads a little low...
dude thats an impressive mph.
isnt that good for low 10's?
nice one.
Jeremy
Wheel spin usally happens at max torque point which is well before it starts to loose power, but looking at the mph and the power they deffiently dont match.
Could be a tuning issue possibly a who in the ign map?, also try bringing the intake back to 0deg and leave the ex at -3.
If none of that works then you have a restriction somwere maybe start with basics, exhaust system?
altho in saying that it does hold boost well you just need to turn the F/B Speed down or even turn it off to fix the mountain like boost curve...
By the look of that i would have said that your lobe centres are too tight. You've got to remember that in tightening your lobe centre's your reducing your power band. Also as cameron said you feedback speed is set to high - thats why your boost is oscillating.
Edited by rob82
awesome info guys thanks alot for that its really appreciated...
Im getting a bigger wastegate spring soon so the duty isnt up around the 60s for 1.3bar of boost...
the dyno does read low for my car, i dont know why but my car never reads right on it...on 300rwhp the car ran 124mph trap speeds, and now on 365rwhp im running 130mph trap speeds...
definately cant wait to fix the boost and power band up and go back to the track and crack a 10!
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
