i dont think there is actually anything wrong with the turbo itself...its big and heavy and oldschool design. Mine didnt actually stuff up permenantly, my mate pulled it apart and cleaned the carbon build up out of it and put it back together and its now on his turbocharged xe falcon, 250xflow with a t70 and it is actually half quick now. Big sleeper haha.
https://www.sau.com.au/forums/topic/140893-t70/page/2/#findComment-2631793
i had 1 on a rb30et full boost by 4000 or so.
made 253 rwkw with the injectors maxed on 17 psi.
the guy i sold my motor to using biger injector's has pushed it to 330 rwkw not to bad.
good elcheepo turbo.
i just used the car for a burnout rig and the motor was just aq convert with copper head gasket cam head work and your normal vl mods.
still would pull 3rd gear nuts not a prob
im mising having a semi quick car.
hate driving a r31 rb25de with no power.
shuld hurry up and bold my rb25/30 together and slap it back in the vl
https://www.sau.com.au/forums/topic/140893-t70/page/2/#findComment-2641923
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
