Guest Diabolik1
Hey all,
I just recently noticed that my car is getting hard to start...
On friday night it just couldnt start at all....i thought it was the alarm so the alarm guy came out, and we successfully started it with jumper leads....
I then bought a new battery, a bit bigger one, and this morning it was very hard to start again..
it would have to be either electrical or fuel....i checked out the fuel, and its there, its getting the fuel....so even with a new battery it would have to be electrical right?
has anyone else had this problem?
it starts cranking, and just cranks for a long time and u gotta do that for maybe 2-3 minutes off and on for it to hopefully start.
could ultra tune maybe fix this?
cos i dont have time to take it to HILLS cos i need the car this weekend, and theres an ultra tune near work...
thanx
https://www.sau.com.au/forums/topic/14093-problems-starting/
Guest Diabolik1
doesnt it cheese you off that it takes you ages to start the car and youre nearly draining the battery everytime u do it...?
i might just take it to Hills and live without it for the time it takes Mark to figure out what it is, unless he already knows what it is...
Ill let u know either way.
https://www.sau.com.au/forums/topic/14093-problems-starting/#findComment-283147
When it cranks, does it crank slowly?
My guess is that something is draining the battery when you leave the car, and making it hard to start later on. But, when you leave it off for just a few seconds, it'll restart no problems because it hasn't had time to drain the battery.
Use a multimeter and check if there is significant current flow from the battery when the car is off.
https://www.sau.com.au/forums/topic/14093-problems-starting/#findComment-283176
Guest Diabolik1
No, it cranks very fast..specially with the new battery.
i just rang Mark from Hills and within 2 seconds he said "Fuel pressure regulator" i went to Hills on my lunch break and dropped the car off...
Hopefully pick it up tomorrow or if Mark is too busy, on tuesday.
Ill give ya all the rest of the details when i get the receipt.
Thanx all for your replies
https://www.sau.com.au/forums/topic/14093-problems-starting/#findComment-283300
I've got the same problem.
My initial thought was the injectors but after reading the post, the fuel pressure regulator makes sense too.
If this is the case, would it be affecting the car in any other way ie performance ??
Be interested to see your comments when you pick the car up Diabolik.
Please inform us of price too.
https://www.sau.com.au/forums/topic/14093-problems-starting/#findComment-284223
Guest Diabolik1
I made a post about 2-3 months ago about my car sometimes just losing power.....in 4th gear driving about 60, and then accelerating slowly to around 70 it would lose power for about half a second and then get back on its feet...that i bet was due to this aswell...
also while driving to work yesterday and to Hills, the engine died once while i was at the lights, and lost power for a second about 2-3 times...so it was really starting to get bad.
ill let ya know all the details as soon as i get the car back...i miss it already...im driving around in my gf's dad's V8 statesman, so if u see an ugly statesman give one of you guys in your skylines a thumbs up...dont swear at me and say hello back, heheh
https://www.sau.com.au/forums/topic/14093-problems-starting/#findComment-285047
Guest Diabolik1
Hey,
Well after a week of my car being at Hills, its fixed and i will be on my way to pick it up in 2.5 hours.
It ended up being the ECU.
It wasnt getting a cold start signal, and it wasnt getting fuel..
Theyve changed the Fuel Pressure regulator, but the problem still happened, and after changing the ECU with a new one, prob was fixed.
So if anyone else is having the same problem, check this out...
Thanx again.
https://www.sau.com.au/forums/topic/14093-problems-starting/#findComment-295014
Guest INASNT
Originally posted by Diabolik1
Hey,
Thanx again.
Just for that hills took a week???
https://www.sau.com.au/forums/topic/14093-problems-starting/#findComment-295037
    • Had a chat to Tony Mamo - he advised that looking at the graph's shape (regardless of number translation) it shouldn't be levelling off like that up top. He said it looks like the car is running a restrictor plate or something of that nature. Luckily the last dyno pull on E85 was saved to the PC - So I did a quick trace of Barometric KPA vs Intake manifold pressure, and lo and behold I see a copy of the 'waves' I was seeing on the dyno: I'm not entirely sure how to go about addressing this. It may be worth sacrificing IAT to run a more direct intake for the motor. Though packaging this could be flat out impossible given the constraints of the car. I should have removed the intake pipe to see if this made a difference but looking at this graph I now have something to potentially test in the future and think about. This one is from an old track day log in the OLD setup going through gears on track.
    • Oh, I forgot too, all the multimedia stuff captured and sold through things like people playing Pokemon Go. Pokemon Go specifically, can actually be traced all the way back to a CIA investment company too. So yep, they're watching everything. Not to mention the new stuff where they've worked out how to use WiFi signals to be able to map occupants inside of a building. That one would be something that I see being more used in public/government buildings, as you need to understand the signals when the room has no one in it first. It's not as easy as Hollywood would like you to think it is.
    • Followed ☺️ Assuming those are NEO rods, then at least 400kW all day.
    • Lets keep this going , Spotted this very stock V35 in Penrith and also saw a nice R32 FLY past me on Castlereagh rd , sounded really good.
    • Great work! Give it a clean up with some Emery paper, and I'd run a thread die over the threads too to clean them up. It will make reinstall much easier, and also life easier for the next time it needs to come out.
