  • Replies 53
The point I was trying to make (With or without the one being carried) is that belting a kerb to a degree is analagous to the random brick on the road the solution to which is the pretty much the holy grail of active suspension. You want compliance at that point.
Are your spring rates and bar rates higher?
They both are.
My OEM spring rates are 5.9kg / 6.5kg F/R. The Flex run 12kg F/R.
Not sure how thick my new swaybars are, but they're definitely thicker (about as thick as you can get, apparently) and solid instead of hollow.
Given how skittish the car is with 12kg springs on the street, if I don't find the car easy to drive on the track I'll drop down to a 10kg spring. Should that still not give me the powerdown I want, I'll put my OEM rear swaybar back on.
What car is it to have higher spring rates in the rear? The big cast iron engine is up front so woudl expect the higher spring rate to be at that end.
My engine is alloy. Its a 350Z.
Considering my car's weight bias is to the front, and my spring rate bias is to the rear, I just cannot for the life of me explain why the damned thing understeers so much in stock setup.
Caster and camber, the way Nissan designed it
Understeer is good for the Wallies
When they rush up to a corner too fast, so understeer is better as it scrubs off speed
Oversteer and Wallies don't mix, flying off backwards at undeminished speed is not good
:( cheers :no:
There's no doubt that most of the understeer is engineered in. Getting rid of the staggered tyre sizes, and different swaybars, cured most of the understeer.
Probably the best "bang for buck" handling mod I did to the car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
