Hi all
My current rims have a chrome lip, and due to brake dust there has been some slight tarnishing/patchiness/staining and build up of guk on the bits of the chrome.
I can kinda scratch it off with my finger nails, and in some sections, it just looks a bit tarnished.
Tried some light polish, some meguiars products, nothing can get it off.
I am guessing its due to the brake dust because the rear wheels are completely fine, just the front rims.
It kinda looks like water marks and is not as smooth when you run your finger over the chrome lip.
Any suggestions on what I can do?
Thanks all
Edited by nuffsaid
i read somewhere about this. there really isnt anything you can do apart from getting your rims resprayed to look like new again. the best thing to do is when you have new rims is regularly clean them because its the dirt and brake dust that damages them
metho will remove the staining, but if you want to give it a go, be EXTREMELY careful and make sure you don't get any on the tyres. Put the metho on a rag, apply it directly to the stained areas and rub.
*Disclaimer: If your tyres melt, i won't take responsibility for it! :thumbsup:
If you want to try something a bit safer, have a go with some autosol.
if it's chrome, spirits shouldn't dull the finish, if you're scared of scratches, make sure you get any surface grit off first.
If you have the slightest concern about using spirits near the rubber, then try autosol first
if you can't find autosol (or don't want to spend money on something that might not work) go and raid the kitchen.
vinegar and bicarb is a very user friendly (and enviro friendly) combination for any cleaning task!
Pics of before and after?
I have this problem with one of my sets, the worst part is, the national electroplating union says no one in Oz does car wheel dipping, heaps do trucks, but none to car rims....
I put some Meguiars paint cleaner on it yesterday and rubbed the hell out of it with a terry towel. Seems to have cleared up most of the problem.
Also scratched off the really stubborn bits with my finger nail heheh
Anyone have any other good tricks?
depending on the type of chrome you have.. if it's not high quality take care not to use any abrasive products like Autosol or cutting creams... at this stage you'll need lots of elbow grease and WINDEX... and use a cotton cloth like an old T-shirt.
Yeah I think I may have already slightly scratched it, its not really noticeable anyway so I am not too fussed.
I waxed the chrome part of the rim so that the brake dust should come off easier next time.
Alot of elbow grease went into it last nite, most of it seemed to have come off.
The chrome feels very plastic-ky though, not like solid metal. seems as if there is a clearcoat on them
my point exactly..try not to let the dust build up...if it's black dust maybe you should consider changing your brake pads to Bendix Ultimates as the dust is "white" and not as harsh on chrome.
Its brown dust, that usually, if i wash my wheels once a week, comes off really easily. Problem is this time I left it on to bake too long.
My Formula Ferodo pads are just way too dusty for me, maybe on par with Ultimates, but they give off a brownish dust which is the adhesive compound in the pad material moreso than metal filings.
I have given up on finding performance pads with low dust, i think its like asking for good tyres that last a long time.
Many mag manufacturers have total control over their products, which means that some multi piece rims can't be disassembled by anyone other than the manufacturer.
If this is the case with the brand mags that you have, the only option is to send them back to the manufacturer for repair/restoration work.
However, unless the finish on the plating has somehow been compromised, they wouldn't need to be re-plated.
There are heaps of places that specialise in mag wheel polishing/restoration, but after having a quick look, I couldn't find any local to you. :)
Thanks for that mate ;)
yeah i spent a day ringing every place in Australia, no one will do them back to how they are now :O
All i can do for them, is have them polished and the middles sprayed with black (powdercoat), but thats a fair bit of hassle, i think its time for them to go
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
