yeh i have done mine... awsome right up!
i forgot the bottom o-rings :P hydro locked a cyl. hahaa..
but when that was doen was awsome... now running 250.1rwkw in my 32 rb25 :P
cheers again!
  • 3 weeks later...
  • 2 months later...
Hey there guys, Thanks Alan i found this really important. But i thought i would make people aware of this, Be VERY CAREFULL when trying to remove the fuel rail and injectors out. And look at the end of the injector and make sure all off the 4 prongs or claws on the orange pintle cap are attached. Because i am currently sourcing the 6 pintle caps and there not easy to chase down because they are so wanted :starwars:
Hope this helps Cheers Rob
  • 7 months later...
Great DYI mate
Installed my Tomei 555cc today which replaced the std R33 GTST injectors.
I didnt remove the AAC, didnt get in the way at all for me. nor did the FMIC piping.
For cracking the injector cap screws i used multi grips.
To get the injector out of the rail i used a flat head screw driver and slipped it under the injector plug then twisted the driver to lever it out.
when i changed the power fc injector config, i used the following. Old Injector CC / New injector CC x 120 = 82
my power fc was configured at 120% for each injector...not sure why it was set like this but the above achieved a nice idle. i did actually test 66% based on the x100 calculation also...and idle went to hell...
  • 5 weeks later...
  • 1 year later...
  • 4 months later...
  • 5 months later...
no...it will probably start up and idle ok but soon as you put it under load it pretty much floods it..then plugs will foul then it all falls apart..i tried it once, got around the block but barely made it home..lol
but if you have access to your ecu just find out how to change settings..
  • 5 months later...
really good writeup. i have a powerfc waiting to be installed in my series 2 gtst but i wanted to upgrade injectors first two quick questions..
1; will injectors give me much more power once installed and tuned with the power fc
2;where is the best place to get hold of some injectors and what size is good when chasing 300 to 350 hp?
cheers
  • 1 year later...
Hey guys, know this is a pretty old post, but need to know if there are any major differences when doing this for an rb20det ?
any steps added? important things to note?
anything will help, cheers
  • 2 years later...
  • 4 years later...
14 minutes ago, SKY5HW said:
Nice write up and presentation, my question is will we need to dyno the car once everything is fitted back?
If you change to different injectors  it needs to be tuned.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
