yeh i have done mine... awsome right up!
i forgot the bottom o-rings :P hydro locked a cyl. hahaa..
but when that was doen was awsome... now running 250.1rwkw in my 32 rb25 :P
cheers again!
  • 3 weeks later...
  • 2 months later...
Hey there guys, Thanks Alan i found this really important. But i thought i would make people aware of this, Be VERY CAREFULL when trying to remove the fuel rail and injectors out. And look at the end of the injector and make sure all off the 4 prongs or claws on the orange pintle cap are attached. Because i am currently sourcing the 6 pintle caps and there not easy to chase down because they are so wanted :starwars:
Hope this helps Cheers Rob
  • 7 months later...
Great DYI mate
Installed my Tomei 555cc today which replaced the std R33 GTST injectors.
I didnt remove the AAC, didnt get in the way at all for me. nor did the FMIC piping.
For cracking the injector cap screws i used multi grips.
To get the injector out of the rail i used a flat head screw driver and slipped it under the injector plug then twisted the driver to lever it out.
when i changed the power fc injector config, i used the following. Old Injector CC / New injector CC x 120 = 82
my power fc was configured at 120% for each injector...not sure why it was set like this but the above achieved a nice idle. i did actually test 66% based on the x100 calculation also...and idle went to hell...
  • 5 weeks later...
  • 1 year later...
  • 4 months later...
  • 5 months later...
no...it will probably start up and idle ok but soon as you put it under load it pretty much floods it..then plugs will foul then it all falls apart..i tried it once, got around the block but barely made it home..lol
but if you have access to your ecu just find out how to change settings..
  • 5 months later...
really good writeup. i have a powerfc waiting to be installed in my series 2 gtst but i wanted to upgrade injectors first two quick questions..
1; will injectors give me much more power once installed and tuned with the power fc
2;where is the best place to get hold of some injectors and what size is good when chasing 300 to 350 hp?
cheers
  • 1 year later...
Hey guys, know this is a pretty old post, but need to know if there are any major differences when doing this for an rb20det ?
any steps added? important things to note?
anything will help, cheers
  • 2 years later...
  • 4 years later...
14 minutes ago, SKY5HW said:
Nice write up and presentation, my question is will we need to dyno the car once everything is fitted back?
If you change to different injectors  it needs to be tuned.
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
