Evening / Morning all.
I am thinking about heading to the GC for a working holiday but am unsure on what the good areas are to look at living? Can someone please rattle off some good suburbs so I can check for availability on realestate.com.au
Thanks heaps!
https://www.sau.com.au/forums/topic/140973-realestatecomau-gold-coast/
runaway bay, biggera waters, benowa, hope island
What sort of area do you want to live? the goldcoast has a lot of contrasting areas... from the beach scum side (surfers) through to the classier beach side, to the expensive water front properties.
You going to need to be close to the freeway? driving a lot locally? etc... All makes a difference.
I am unsure yet. I am hoping to finish up my debts here and move across into a retail job selling bathers or towels or thongs or something totally stress free for a few months, hopefully being able to surf and having a lot of spare time on my hands.
If you're doing that sort of thing, might be better off down south end..
I've recently just moved down to coolangatta 1 min from the beach.. beautiful beaches down that end. More surf stuff down there, but nothing is too flashy. Overall though it's nice and cruisey.
If you want something more upper class and more central near the beach, probably Broadbeach or Broadbeach waters might be a good choice.
Expect your insurance premiums to skyrocket, I went from $1250 a year for an R32 GT-R living in regional queensland to over $2500 when moving to the gold coast area, particulary Southport... Anywhere around the Southport area and expect to get your car stolen, it's pretty bloody common.
I'm going to list some good and bad suburbs, but even the good suburbs have undesirables sometimes only a stones throw, unless you want to fork out a couple of million for a waterfront block at Isle of Capri or another gated community.
Wealthy and Middle/Upper Class Suburbs - Generally Low Crime:
Sanctuary Cove
Runaway Bay
Hope Island
Chevron Island (Parts of)
Isle of Capri
Ephraim Island
Varsity Lakes
Middle Class Suburbs:
Pacific Pines
Beenleigh
Benowa
Carrara
Coomera
Ormeau
Tugun
Molendinar
Bundall
Blue Collar Area - Mid to High Crime Rate:
Southport
Labrador
Ashmore
Nerang
Chirn Park
Property here is expensive... you also have the option of buying a unit in Main Beach...... but expect to be kept awake from nightclub noise most nights if you are near cavill and your unit is less then 30 levels high.
i live on the beach at tugun, and im much more a fan of the southern end of the gold coast ( as in south of burleigh heads )
northern suburbs are ghetto as ( southport, labrador, nerang, helensvale )
but surfers is awesome if your into the club scene, i have friends living there..
id say get a cheap jetstar ticket or somethin, come down for a weekend and see for yourself =]
oh and beenleigh is dodgy as f**k, lol..
Pretty much sums it up, but as Parag0n said, expect your insurance premuim to go up, mine went from 1700 in noosa to 1935 in mermaid waters
depends if your looking to live with other people or not... i live in arundel which is right near parkwood.. never had a problem with crime.. its a 5-10 min drive from beach.. depending on speed/traffic ^_^ and 3 minute drive to the highway.. but most these places are 300p/w+ for a 3/4 bedroom etc.
i love it coz i can get everywhere that i need to go..
..and the uni is around the corner too which is handy coz getting a carpark there is bad.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
