OK guys and gals
I have an R32 GTR with a twin plate clutch that is in need of repair / replace. It has not started to slip yet, but I get some serious groaning sounds when at the balance point, and the clutch only needs to be pressed about an inch for it to disengage (which I understand can be adjusted – yes ?)
So ..... I have a few questions.
I do not know the make/model of the current twin plate as it was in the car when I got it just over 2 years ago.
1: It's an '89 R32 GTR – so how do I find out if it's a push or pull. Could it have been converted. (apologies in advance if this is a silly question :D)
2: Should I reco the exiting twin plate or replace it with a conventional single plate clutch. The car is a daily driver – currently seeing about 300awkw.
My current thinking is to swap over to a single plate to make the car a little easier in traffic (as long as it can take the stress) and sell the twin plate on the forum.
I'm open to suggestions and recommendations here pps
https://www.sau.com.au/forums/topic/140975-r32-gtr-clutch-questions/
1. more than likely it's push. but it's easy to check, just get down on the ground and have a peak at the slave set-up. see if it's push or pull.
2. depends if you are happy with the current clutch. if not, then search out something else. if you are then a rebuild may be the go.
thanks BB
just checked - the slave cylinder seems to be a push type to me
I am happy with the current clutch - but if I can get a better fly / clutch / presure plate setup for the same cost as a rebuild - I'd consider it
I'm guessing that a rebuild should be around the $1200 mark - is that a fair guess ?
well if it's OS Giken and the flywheel is ok, and the diaphragm is ok, and the bearing is ok, then you just need:
pressure plate disc
sandwhich plate
2 X clutch plates
new bolts
cost will be around $1K and you can "rebuild" it yourself. Just pull it appart, and re-asemble in the same order it came appart. :thumbsup:
pressure plate disc
sandwhich plate
2 X clutch plates
new bolts
seems like a lot of IFs in that post :laugh:
how difficult is it to remove the g-box ?
If I get my mechanic to do it - how many hours ?
Edited by itbmils
remove and replace gearbox, inlcuding replace clutch probably about $400. could be as low as $300 and as high as $600 depending on where you go, and what they charge.
Silly question, sort of, but if you have a traditional rattling twin plate and have it recoed is it possible for it to be modified so as to do away with the rattle?
I wouldnt think so..
whats wrong with the rattle?
im in exactly the same boat as itbmils
say we dont rebuild the twin....would say, an xtreme 5/6 puck ceramic be able to hold 300-320rwkw if limiter launches were to be avoided and not overly ridden?
I just spoke to Xtreme. They advise to use the XTRA XTRA HEAVY DUTY DSB clutch range which should support up to 350-400 rwkw on a GTR.
For my late 93 R32 GTR (pull type) Im considering the KNI25003DSBXXHD kit. Its a 6-button carbotic clutch with about 1500kg clamp pressure.
Should be very street drivable and should take the punishment of circuit racing and the occasional rev-limiter launch. They reccommend 'solid centre' clutches for constant drag racing and high rev launches. DSB range is a good compromise for street/track!
http://www.xtremeclutch.com.au/knowledge_ratings.htm
I was quoted $1500 by Jim Berry to rebuild a Nismo twin, for that price id just buy a new one and throw the old one away :)
I am in need of a new clutch an a Nismo Supercopper Twin is what I am after.
$1650ish from Perfect Run, not delivered. $1850ish delivered from Nengun.
Then $400-$600 fitted you say?
I need a new one aswel!
Hows the timing ?!
Anyway.....the ones im looking at are:
Nismo twin from Nengun
http://www.nengun.com/catalogue/product/509
Nismo twin from perfectrun
http://www.perfectrun.com.au/performance%2...ppermixTwin.htm
For early ones though there are 2 choices:
670ps 9807 (1000kg)spring rate 3002A-RS594 ¥150700 Only for push type cluch
Standard spec
740ps 10787 (1100kg)spring rate 3002A-RR593-C ¥162900 Only for push type cluch
Competition spec
Now the 670 one would be the quiet one, and the 740 would be the rattler ( AFAIK ). The rattling doesnt bother me, but if the street spec one will do then that will be the one to go for ;)
Also, perfect run have this page
http://www.perfectrun.com.au/ordering/freight_list.htm
...which shows shipping costs, unlike nengun who of course do it for you
I have considered all the other twins out there, but the nismo ones have the best reputation from the people ive spoken to about them. The next one in line would be an OSGiken twin - but without trying for a discount from anywhere, have a look here:
http://www.otomoto.com.au/osgiken/str_twin_plate.htm
I guess the wholesale would be around the same as a nismo twin delivered ;)
When do you need your clutch by if you dont mind me asking?
Why you wanna split freight?! :blink:. I can put up with mine for a while, its still bites pretty good so its drivable. I need to pay off my suspension first anyway. But before that is Christmas ......ah, I need so much money right now!
Mine is an August '93 model so I need the pull type standard 3002B-RS599
Why you wanna split freight?! :(. I can put up with mine for a while, its still bites pretty good so its drivable. I need to pay off my suspension first anyway. But before that is Christmas ......ah, I need so much money right now!
Haha, shame you're in W.A. otherwise we could do that if you wanted
Yeah i want to look at the OSGikens a bit more before spending the cash to be honest, so ill keep on it :blink:
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
