Car started fine at work! i got home. pulled up in the driveway. turned off car. opened roller door (electric door has had the dick for some reason) and went to start it again! and it was like i had no battery at all.
got dads car out and jumpered it. got it inside the garage and left it run for a bit. turned it off.. tried to start again and the dash lights barely light up.
i have a dry cell sealed battery which i have never ever had a power problem with. tho i did get it out of a car at my brothers work. so it is slightly second hand :thumbsup:
is there anything other than the battery that could be my problem??
Car be the 32 gtr
Cheers
Andrew
sounds like alternator to me. check the battery with the car off make sure it's ok, then check what the altenator is putting out when the car is running.
Battery reads 12.7 when turned off
When i try to start now, I hear what i think is the fuel pump trying to kick over. and the dash lights are faded. but then they come alite and fuel pump kicks in for a second. then it goes all dim again.
ok now with what i'd say a shorting sound somewhere at the rear of the car above the fuel tank???
Thats the only way i can descrive the sound.
Tho i think i usually hear it when its running good. cant quiet remember
Edited by Angus Smart
There are any number of previous threads that describe how to test and evaluate these sorts of problems.
My initial guess is a dead voltage regulator.
well generaly speaking. its alot easier to just ask. considering I DONT KNOW WHAT THE PROBLEM IS
and to check for a dead voltage regulator is done how?
clean the battery terminals... check the voltage after the terminals while cranking ill bet you find a massive drop. if it was the alternator, the car would have cut out before you got home, and not continue running after you jump start it, and battery wouldnt show 12.7v either.
Yeah a massive drop is what i found! down to around 4 volts.
i had battery on charge all night and tried to crank it in the morning. also with my jumper pack. which also seems it had the dick yesterday as it wouldnt charge up over night either.
the battery terminals are very clean! its a dry cell battery so they dont really leak or get dirty.
I didnt get to check the alternator. as i had to move too many cars around to be able to jump start it.
This would have to be the first electrical problem i've had! the car hasnt missed a beat!
You need ~10V to turn the motor.
I had the same problem as you about six months ago. Battery was flat. It also read 12V static but you could see the drop on the voltmeter as you cranked it.
PS You'll receive more help around here if you keep your cool.
sounds to me like the battery is dead. how old is it? try to find a letter and a number thats been burnt/melted into the top of it. example. L6 would be november 2006. letters are for the month except they dont use I cos it looks too much like a 1 A=jan B=Feb...H=Aug J=Jul etc
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
