hey there guys, as above just wanting some recommendation for my R32 GTS-t
Thanks
Gordon
It really comes down to a few things:
personal preferance or size
budget
and how readily available are tyres.
I run 17" Drift Teks on the front and rear but i also have R32 GTR 16" for the rear.
Tyre price is what really makes the difference for me though.
Just make sure that you run the same size rims on the rear at the same time and the same brand/make/profile tyre :D
Cheers GMB
yes
i always have 235/40R18 on the front, and have run 195/55R16 on the back before, just for shits and giggles.
usually i run 235/45R17 on the back though. commodore/falcon size, easy to get a hold of
I assume you mean wider tyres at the rear. A lot of guys run wider rims at the back. If you're only going to fit 17 x 7 rims you might as well have the same size tyres on both ends. That way you can rotate them to help wear. 17 x 7 will fit easily as long as the offset is ok. Check out the wheels and offsets sticky thread.
If you are just starting out in drift, I strongly recommend you dont go overboard on rear tyre size - the difference in grip between a 205 and a 235 is pretty noticeable.
I would recommend going larger than 7" for the front, get some decent tyres on there, as front grip is really important - understeer is ugly :)
Buy some decent rims for the street, get good rubber up front, and start out by just using stockies or similar for the rear, much, much cheaper, and alot easier for learning - until you get some decent skill, and your speeds increase, then a little more grip will help, this sometimes can take upto a year or two.
good luck
so i will just decide on the rims i will be getting and when i will go out for drift practice i will just stick on the stockies again on the rear. thats the way to go ay??
flash89, go too big on the rubber, and your car will handle poorly due to excessive sidewall flex
If you want good traction, make sure you have good suspension, and ALL the parts are in good condtion, get a good wheel alignment, and use good rubber
You may be surprised to know, a good drift setup is very similar to a good grip setup. Option publised a dvd with D1 drift cars doing grip laps around tsukuba, some lapped in under 1 minute, which is considered very quick
there are a lot of things to consider
-low powered cars should use smaller tyres/rims as they are less grippy
-if you're using second hand tyres, 16s and 17s are more common than 18s
at the end of the day there is no 'good' tyre. For something less grippy some stock r32 or r33 wheels are ideal (16x6.5), you can use 195-225 widths and 45-55% profiles, also these sizes came stock on alot of commodores and such so there are plenty of them second hand
For something mid-range stock r32 gtr or z32 are good (16x8 and 16x7.5 respectively) with similar sizes to above (the wider 225 end of the scale are preferable).
For something with better grip for the rear, 17x8 and 17x9 with 255/45 etc.etc. is usually the go.
I avoid using 18s because of the cost of the rubber.
You will also get variations in grippyness due to the compound of the tyre, hardness etc.etc. so you can get 205/50/16s on stock r32 gtst rims which are grippier than some 255/40/17s on 9inch rims
also number 1 bet on tyres for drift are Pirelli P6000 they are the most consistant drift tyre i've ever used on 16s
if your just starting out drifting
use ur stock rims, 215 or 225 wide tyres
as steve said no point going big from the beginning because it will make it harder to learn.
ohh and anything 7inch wide is way to small , you want a MIN of 8inch wide; 8inch wide will run 225/235/245 without a problem *i think you can even get a 255 on it*
good luck with ur drifting, its great fun :P just be careful and dont damage the kit u got
cheers michael :dry:
if you want reasonably priced rims, Beaurepairs in Myaree sell drift tek rims - $270 for 17 x 8 and $295 for 17 x 9, both +30 offset - these rims are identical to Uras NS-01, but alot cheaper
they are also selling 215/45R17 Antyres at the special price of $105, but you gotta tell them they are for drift, cos otherwise you pay $150 each - you will also need to speak to Yang - the manager.
For a reasonably grippy tyre at a reasonable price, I have found Federal 595 SS are quite good, or if you want hardcore grip, the Federal 595RS are excellent, and the cheapest R comp tyres around, but they wear very well.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
