**** EDIT, back on the market. New info added ****
BNR 32 GT-R For Sale
I never thought this day would come, but due to a change in circumstances I have to part with my beloved GT-R. Ive owned this beauty for 6 years, its been the longest ive ever kept a car & the best one ive owned. Wish i could keep it, ive poured bulk $$$ into it, most during 2005.
1990 BNR32 SKYLINE GT-R
Imported under the old system in 1999.
Travelled 102000ks, had 81000 on it when I got it 6 years ago.
ENGINE & SPECIFICATIONS :
RB26dett
R33 Block, machined, bore, hone, decked, tap oil galleries, resize prepped std rods, balanced/blueprinted
R33 Crank/spigot bush ( both new )
Reco’ed head, new guides, face valves, cut seats, skim head, new stem seals, shims.
New cam belt. Idiers, seals, sump plug helicoiled.
New Rubber Hoses
New Nismo main bearings and conrod bearings, oil system modified.
New Engine mount rubbers
New radiator & all new rubber hoses, clamps seals etc
Tomei 87mm forged pistons
Tomei Special piston ring set
Tomei 260 Poncams
Tomei Complete gasket set (incl metal headgasket)
Jun Oil Pump
N1 water pump
HKS cam sprockets
Nismo Oil Cap
Nismo Radiator Cap
RacePace Custom catch can
Optima Battery
Custom engine covers in “Millenium Jade”
All done in August '05.
INTAKE & EXHAUST
K & N pod filters
HKS Suction kit
HKS Hard pipe kit
Standard GTR Intercooler
Trust 60mm x2 Front pipes
Racepace “Race” cat
HKS Super Drager 100mm Exhaust
TURBOS, ECU & FUEL
HKS GT25/30 Turbo kit
HKS Type 1 dump pipes
Nismo AFM's
Apexi Power FC Computer
HKS Evc 4 Boost controller
Sard 700cc injectors
Bosch 044 Fuel pump
DRIVETRAIN
Racepace Custom single plate clutch
Racepace modified Rear differential
Machined flywheel
SUSP & BRAKES
Bilstein custom coilovers (Set up correctly by Ben )
Cusco Strut Brace
DBA crossdrilled Rotors, new rubber boots all round
Standard Nissan Pads
New Cradle Bushes
WHEELS & TYRES
Volk Racing TE37s 17 x 9.5 Bronze
Volk Racing genuine lightweight wheel nuts
Falken Azenis ST115 255/40/17s
BODY
Silver Repainted ( Before I got it ) (Nosecone resprayed Oct 06)
BNR32 Nismo Bumper slots (genuine ones)
Tinted windows
INTERIOR
Trust Twin A pillar gauge mount
HKS Boost Gauge 60mm
HKS Oil pressure Gauge 60mm
Nismo 260k dash (original incl )
Genuine Nissan GTR Floor mats
GREX gear knob (original incl )
Nismo Short Shift Kit
Retrimmed gearboot
Panasonic Headunit with stacker control ( not hooked up )
Power
334rwkw @ Racepace in non-shootout mode with pump fuel on 20psi. Easy tune. Much More in it.
***EDIT, retuned @ Racepace now 348rwkw, better midrange too***
Serviced, Built & tuned by Ben @ Racepace Motorsport in Bayswater, possibly the best GT-R workshop in Australia. Engine, Diff etc all only 2000ks old.
Only the best lubricants used.
Never track raced, treated like a baby. Driven rarely hence the Ks since I got it!
Receipts for all work done.
Asking price $34000
Contact Details : rod@nocky.com
gtr26@netspace.net.au
Cheers
Rod
post-1076-1162195365.jpgpost-1076-1162195497.jpgpost-1076-1162194959.jpgpost-1076-1162195096.jpgpost-1076-1162195256.jpgpost-1076-1162195890.jpgpost-1076-1162386702.jpg[attachmen
Edited by RNGTR
https://www.sau.com.au/forums/topic/141073-bnr32-gt-r-highly-modified/
NO NO NO!!! I told you not to put it on the market and I will buy it off you in 2 years!!! lol.
Well If I can't have it then someone else will be very lucky! This car is immaculate and anyone who purchases it will be getting a great car.
Good luck with the sale Rod!
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
