Hey all,
I purchased my first skyline about 2 months ago now (1995 R33 GTSt). Claiming that it has done only 60,000ks... im sure thats crap with how easy replacement clusters are to get, but the actual car is in very good condition.
Now i seem to get about 320km out of a full tank of PULP (V power) and i just think that i should be getting more than that considering i dont very regularly drive it hard.
The car is completely stock minus the factory air box being replaced with an Apexi power intake. But the effeciency was about the same when i did have the factory intake.
The engine seems to run very smoothly but can sometimes produce a very off smell that may last for 30 seconds and then all is fine again for the rest of a day of driving... (i thought the smell issue may have been a clutch issue at first as when i got the car it happened mainly when reversing... high slippage when parking, but now its just very random)
Any ideas or suggestions?
Cheers
Cam
https://www.sau.com.au/forums/topic/141124-r33-fuel-efficiency/
  • Replies 69
Posted Images
Lots of topics on this.. Do a search!!
320km on a stock 33 is really bad..
You might need to do a full service.. Maybe replace 02 sensor.
Car running rich but? Shouldnt be if its stock!! if it is might need a tune up..
Maybe also replace fuel filter and oil filter..
As for the other issue if its the clutch then you should know it immediately. Does the car tend to rev but not go anywhere??
Or the clutch only slips in reverse gear??
Probably worth gettin a new clutch then reconditioning it.
firstly, how many litres are you talking about as a full tank?
secondly, how 'spirited' is your driving?
thirdly is it city (where you may be sitting in traffic for a bit) or highway?
all of these (especially the first one) will determine whether your economy is good or not.
:yucky:
if you're talking 320kms on 45 litres, then that's 14L/100kms. that's not too bad in city driving, boosting occasionally. if you live out in the sticks, then alot of freeway should see that figure go up quite a bit, maybe 11L/100kms.
Lots of short drives also consumes more fuel as the car isnt up to optimum operating temps.
Also, driving style makes a big difference.
I wouldnt say this is terrible economy.
Im running stock boost, Blitz Pod and HKS Priest catback. I get about 320-400Km per say 55-60 Litres. That is with a bit of 'Spirited mountain driving' :yucky:
Id say I get between 12-17L/100KM depending how I drive. So it would theoretically be possible to get 500 Kays to a tank... If I put a phone book under the accellerator...
As i did say my driving is very casual 90% of the time so im not wasting juice on that. I'm filling up the tank till the pump wont gime any more :) and running down as low as the guage can basically go, but not enough to turn on the fuel light. I also dont appear to blowing and black smoke, very clean exhaust from what i can tell.
I am mostly doin city driving but i have a place down the mornington peninsular and when driving back and forth from there the effeciency really doesnt increase by much at all (maybe 360-370km). This really surprised me as my old car would give me 100ks more per tank when doin only 100km/ph driving)
As for the clutch issue, no the clutch takes up perfectly fine when driving, no unwanted slipping.. i was refering to like when i reverse park there is slippage caused by myself of cause and thats what first made me think it could be clutch coz thats when i first smelt it, but it doesnt seem to happen then anymore... just randomly during general driving, and i might drive the car for an hour or more after and it never returns.. strange..
i must have typed something wrong as i did do a search for "topics only" on fuel effeciency over the entire SAU forum and got nothing relevant. Most searches ive done using "entire post" has given me so many unrelated posts ive stopped using it..
But thank you all for your responses so far. It's gettin close to its first 5000km since ive owned it so i'll prolly get em to do a more thorough look over the vehicle.
Cheers
Cam
My bog standard R33 GTS-T gets almost 500km to a tank... less if I'm driving, but about that when my wife has it. - I forget what the fill volume is, but $60-$70 at $1.3L = ~45L
That's mainly city driving although it does get ~4 45 minute Hwy trips a week (out to the folks and back).
It's worse than my Lancer, but better than my Laser (although that may have been pissing fuel out of the pump so it doesn't really count).
I havent been able to source exactly where the smell was coming from but next time it happens i'll try and pin point it.
Is there some way i can find out if unburnt fuel is making it to the cat without pulling out that section of the exhaust?
Also what would cause this over injection of fuel? its the stock ECU as u've all prolly gathered so mixture cant be changed there, but would it be becuase say the air flow meter is reading higher readings than is actually making it into the manifold?
Thanks for ya help all
Cam
factory fuel tanks take 65liters of juice
Rather than just guessing what a tank of fuel is, calculate your consumption. When you fill the tank see how many litres it takes to fill it, note your kays & work it out. It does sound from what you've said though as far as the needle reading empty, that your consumption is poor.
If you don't think your O2 sensor has been changed DO IT! I personally left it longer than I should have (& I should know better), it was completely shot & I was getting about 15L/100km. Now I'm doing around 12L/100km give or take a bit. Most of my driving is is the city & I do give it a bootfull off the line quite regularly. Cruising on an interstater I'd see 10's easy, maybe less.
Most people don't realise how important an O2 sensor is to your economy but it's vital to getting good consumption. It should be changed once every 5 years & it's worth it. I'm now saving at least $10 a week or about $520 a year on petrol to what it would cost me if I hadn't changed the sensor.
NTK 1's retail for something like $130, you'll get your money back within 13 weeks if you go through a tank a week at the moment, or even more if you travel further.
Oh & you can probably smell fuel when the car is stationary wafting in though your window or vents, since it'll be running rich as. Look at your rear bar, if it's getting lots of black crap on it she's rich as buggery.
Edited by JazzaR33
So even if my 96 S2 has around 54,000 KMs on the odometer I should replace my O2 sensor?
Hmmm I might do that at the next service... dunno whether to get the EL falcon O2 sensor or buy a genuine R33... any advice?
sir d - NTK make a direct replacement for about 100$ odd dollars.
It's pretty much the same price as the el sensor, but has the correct plug.
I disagree with you guys. I have a consult screen, and I have have used the consult interface with my laptop to graph the o2 sensor output.
My fuel economy is shit - about 300ks to a tank. But the o2 sensor is fine.
Can I have the NTK contacts? A site perhaps?
Cheers.
I think you should follow what siddr20 has said :yes: the filters can make a huge difference.
How many litres are you using?
I do around 380KM to 45Litres (And the needle is pretty damn low!)
I've never wanted to go any further, as I never knew how much fuel and R33 held until just then.
But with my economy... I'm in the 11L/100km gallery.
Sir-d, Kudosmotorsport on here sells them..
http://www.skylinesaustralia.com/forums/in...howtopic=135194
Btw yes changing your fuel filter will help a lot..
But since my car has a few mods and runnin rich, a good tune will help me towards my fuel mileage..
Otherwise for a stock car, i reckon the fuel filter. BUt if people claim 02 sensor helps then worth a try!!
Thanks!
:ninja:
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
