Guys,
I got a r33 gts-t 1994 and when i put the foot down in pretty much any gear about 4000rpm my car starts popping when the revs are going up on full boost. The boost stays the same bit it feels like it surges then back on surges then back on right up to redline...
Would this be a fuel pump or maybe even coils
Im running a stock bov, fmic, cai, and a standard ecu.
Ive have it into a mechanic and they still cant seem to find anything worng with it. (maybe they not as heavey footed as me.
Mind u on 5psi it wont pop only on 10psi it will.
If any of you can lend a falla a hand i thank u in advance
Cheers Matt
BTW i just had a dyno run today came back with 150.7 (stink i know) but around 125km in 4th the line dips and again at 134km it dips again then again at 148km/ph and the guy sasid he fixed it.
IM CONFUSED!!
0.8mm plug gap.. if that no fix rip the center coil cover off, take the car for a spin to get it hot then come home and carefully look for little flashes of light around your coils.
If they flash your coils are nackered and u need new ones. :P
IM CONFUSED!!
Check your fuel pressure regulator has its vacuum source on. If the dyno shop gave you a printout of boost and power they would've taken it off.
ive seen this happen as well.. .7 can also help so try that before looking elsewhere.. in my case i went to .6 :)
no gap the plugs to .7 m i gap my mate to .8 slight improvment but when gaped at .7 the whole mis fire went away
Well i just looked at all the coils and found a little hairline crack, so i had a read of the following topic:
http://www.skylinesaustralia.com/forums/in...56&hl=coils
and wala did what it said. took the coils out looked at them with a magnifying glass and found a small crack, used pvc tape and sweet i have boost again right to redline. Maybe only a temp fix but saved me $$$ on coils i didnt really need quite yet.
Cheers for ya help
Matt :)
    • Yeah I'm happy to talk to whoever, I don't want to take ownership or even manage it if they don't want but I can probably help with hosting on the sau setup. It's a great resource and should be protected.
    • So, got some bits..   New oil filter housing gasket (main problem I'm trying to fix -see leak above)  While you're in there's: New belts, pulley and tensioners.  Vanos oil line New oil drain valve New water pump and pulley  New fumoto valve (all my cars have these). Some of this stuff seems ok now that I've pulled it out but I still have no idea how old it all is.  The belts looked fine and then I noticed this. Like somebody has hooked it with a pick.
    • As the title suggests, Looking for some comfortable replacement seats that will suit/fit an R32 GTR. Purely road use.  Happy to travel to the Tweed, Gold Coast and Brisbane area. Possibly Sunshine Coast for the right seats. Show me what you got! Thanks in advance.
    • Customer states,I got an oil leak.  Customer was raht.
    • Hi friends, I recently got myself back into an R32 GTR with factory seats. The seats themselves are in excellent condition but the drivers seat is a bit tight for my back and become uncomfortable after about 20min of driving. The passenger seat is a little better so I'm not sure what is going on there, almost as if the drivers seat is newer and has not been worn in.  Anyway, I'm looking to replace them with something thats going to be comfortable for road use.  I was looking at these replica seats from Crank Motorsport however there has been a number of reviews of the company that aren't great so i'm a little skeptical.  https://www.ebay.com.au/itm/185466689021?_skw=r32+GTR+front+seats&itmmeta=01JKS72VG115M2Y3KBGCBCWYDD&hash=item2b2ead15fd:g:cMAAAOSwhhZlsIpK&itmprp=enc%3AAQAJAAAA8HoV3kP08IDx%2BKZ9MfhVJKl6v17FmqPFPHrHp4kFm2I9VMAXrpZg5R8sUXH6QLUAkliQu34NiG%2F84PJ05lKf2iGboUiWpWbvHYPYKsT154rul3I%2FaGRskpG8VfgyrwC9%2BdRj7uoDAPGJH%2FVprfvd6pgAN2XmUz6buE9YHvOPCKhtJfsQXhEzwgmVTcIwEkkV0A1r%2FkyJYMmQK0OKLI%2FrM%2FQLzeAOkN9B6WLAPrNyFlml%2FkG%2BYzkTXGJ8LN%2B0NCSLfczQGSYeJqPfvMFMgDL2gOD%2BPWb3sX1D1A6PxY5jqyMGey7zin4sDqrUrA7CpqLLpA%3D%3D|tkp%3ABFBMmriLp55l I also live In the Northern Rivers and these seats are in Melbourne so I can't even try them out before purchase.  Is there anywhere/anyone around the Gold Coast, Tweed or Brisbane area that would have a decent selection of seats I could test out before purchase. A lot of these places seem to be in Sydney and Brisbane. Maybe there's an individual who has an after market item such as Bride or Recaro I could quickly try? Thanks in advance!
