hey guys, my RB30DET needs the valve springs changed but its too hard for me to do so i want to pay for someone to do them but none of the well known/big workshops wanna do it due to the fiddliness of it. so i'm looking for a small workshop perhaps, reasonably close to metro adelaide that you persoannly would recommend/let work on your car and wouldn't mind a small challenge.
cheers in advance, Ash!
by the way don't tell me to rip the head off and do them cause i really don't wanna and i've already asked Shaun @ boostworx and he said he wouldn't do it!
I too have rung around all the major Adelaide workshops and they don't want a bar of it.
Rip the head off they say. If you find some one to do it, my plans may change.
heheh don't want to give it a shot yourself after the cam gear install???? :laugh:
Chris Milton Engineering are the blokes who did the work on my head.
They too said to rip the head off. They only wanted $100 to fit the springs up but wouldn't touch it with the head on the car.
Reason being.. A custom tool is required to be made and really doing the springs on these heads is a pain in the arse.
I'll probably end up ripping the head off and have them do a valve grind while its there, its done almost 45,000km's so it could do with one.
pity his workshop is far from reasonably close to metro adelaide :)
Some maps say Gawler is metro. Most say Munno Para is metro so Gawler is "close". :)
Personally being non metro is fine by me :) Means i can get my car in whenever i want!
could give Dave from The Motor Shop a try
i did work experiance with him many many many ma.. well u get the picture
edit
Motor Shop, The
14 Dewer Ave Ridgehaven 5097
(08) 8264 1972
Edited by Madaz
heheh don't want to give it a shot yourself after the cam gear install???? :)
ye, if i can't even get that right who knows what i'd do trying to install these.
Should offer Andrew (sky30) $100 to do them seeing as he's done them before! hehe!
rang motor shop and john moyle race engines, both said they wouldn't even want to attempt it so i then rang rhemac and they said ye we'll give it a go but i wouldn't get much change from $800 (i don't think so). mmmmmmmmmm dunno what to do!
lol @ $800.
Bugger that.
As that horrid saying goes Ash.. Suck and see.
Push the boost in to it and see how she goes. Your springs have been shimmed up where as sky30 and my won weren't.
Bl4ck32 has had no issues on 16psi with his spring shimmed.
So give it a go. :ninja:
Shaun shouldn't charge much for a retune on more boost as it should only take two hrs including cam gears.
As much as you don't want to hear it, if the shops won't touch it without the head off, then I sure as heck wouldn't be trying it myself.
It sucks to have to take the head off, but if you break a spring and do further damage the cash it would have cost you to fix might seem like chicken feed.
If I remember your dyno graph, you should be right to try and save some cash up, as it only looked like a problem right up top (which is not surprising for valve springs).
If you do end up having to take the head off though, I know I'm the sort of person who couldn't put it back on without some tickling.
I know I hate it when the two choices that I have are ones that I think both suck - "she'll be right" or "big cash bummer".
lol thats my problem. I've already had the head cleaned up with valve deshroud and mild in/exh porting, I wouldn't mind doing a little more work to the exh. side of things. :)
Was that price from Rhemacs to re skim the head as well? They do tend to be more expencive but i've always found they do more as well, they don't do things by halves. The price probably included all new gaskets and seals etc. add labour onto that and it's probably not too bad.
All though Ash asked for valve springs to be done without the head coming off the $800 price is probably to cover incase they had to rip the head off. ;)
It is fairly pricey. Definitely worth the work doing mine myself. Miltons only want to charge me $100 to fit valve springs up so I'll have them do it + throw a different set of cams in and maybe a little more work to the heads exh. side. Hell its all apart anyway.
I'm happy with the head work Miltons did on mine last time, there was a noticeable difference before and after by just feeling around, and the main thing. The economy is pretty damn good being close to what the rb20det used to get. I was a tad worred about porting etc as I had heard a few horror story's of it buggering up economy. ;)
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
