Hey guys,
After a long week of getting my new power FC installed and got my self a terrific tune at Race Pace it has ended badly. I went to race pace thinking that i had a full turbo back 3" zorst however after reciving my car i was told that my cat was a povo 2.5".. :P .. Whats the point...
so race pace did the best job they could gettin 150rwkw out of my car... yea i know dont laugh... just because the mechanics that put my exhast on are very stupid... and ripped me off..
So as the title states i am looking for a Cat converter im not the ritches guy but i do like spoilling my car.
So what brands should i look for???
i have a R32 GTSt looking for 3" cat.
Thanks.
https://www.sau.com.au/forums/topic/141140-catalytic-converter-what-to-get/
There are some cheap ones on ebay, I wonder how they would go... surely the straight pipe that bolts in (ie, no cat) would only do good things. They are about $80 on ebay. If you are running a stock one at the moment, its probably very old and blocked, so you'd notice the difference removing it.
This is the cat you want.
I think it's made by magnaflow, it's a metal cat. It is classified as a 3.5" inlet/outlet cat, one
side is centred, the other is offset. No flanges on it, and it costs about $400 if you get it wholesale.
There might be a GB on that will get you one cheaper.
The actual cat section is the bit in the middle; the other parts have no material in them and are to expand
it out from 3.5" or whatever your input size is. If your input size is smaller, make an expander :yucky:
I sectioned it back to suit my 4" pipework and external gate's outlet - you could probably put this into
6" pipework if you really wanted (but you would be well outside the manufacturer's designed operating
range then).
Am going to get it emissions-tested; when I do, I'll post the results. Seat-of-the-pants feel is that
this single cat outflows the dual 3" catco cats I had on my last exhaust by a little... but that's only
a feeling at this stage :sick:
Regards,
Saliya
Edited by saliya
metalcat 3" cat. stainless outsite, stainless inside! no ceramic rubbish! $280. form the group buy section but you need to flanges put on it or order one with the correct flanges :D mine performs like I have no restriction in the exhaust at all.
sorry to jump in, but now i'm concerned.
what size does my cat look to be. this is a 3 inch pipe before and after the cat.
thats the standard 2.5 inch compliance cat from when the car was imported.
Sorry to say but its time for a new one.
Yea i have been looking at a magnaflow.. but i might cheack out this one on ebay.. not the straight pipe with a bolt on it though not readdy to pay thousands in fines...
Ay monkeyboy looks like u have the same problem as me.. i renember seeing a thread of this guy selling alot of stuff a little while back and he was sellin 2 magnaflows but i doubt they are as HC as saliya's cat damm..
so might want to have a look...
Edited by Fugi
X-Force 3 inch highlow - Stainless Flanged cat - (Flows up to 570 cfm)
$160 delivered from Just Jap. You cant beat that price. It's a forum special. Usually $199+delivery.
I just ordered one.
here's the link if you're interested.
http://www.justjap.com/forumxforcespecial.htm
Edited by Munkyb0y
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
