so i've undone the centre lock nut and the three little grub screws underneath the horn button on my R32 GT-R, but the wheel still seems to be held on by something or other.
anyone know what else i need to do to get it off? or is it maybe just wedged real tight on the steering-column?
https://www.sau.com.au/forums/topic/141169-undoing-steering-wheel-on-an-r32/
feels like something will break if i'm anymore violent with it!
i even loosened the reach adjuster on the column off so i could 'slide-hammer' the wheel when pulling it back
so you're sure there's nothing else that needs undoing?
dude put the nut back on a thread or 2 like the beer baron said and then with your knees push up on the steering wheel the start bang on the back of the steerin wheel towards u it'll come off i had the same prob wid my gtst just bang dont get a hammer and break the shit and make sure the nut is on otherwise u'll rip it off striaght into ur face and have no nose left.
there are two possibilities, either I'm sure, or I'm lying and just want to you snap your wheel!.lol
no, i am 100% sure. both my 32s have aftermarket wheels on them. both of them were installed by me. once that big nut is off, there is nothing keeping it there bar the fact it's wedged on the splines like a mo fo.
just put the nut back on a bit as once it comes free it's going to be travelling towards your head at a rate of knots. I know of a few numb nuts with bloody noses thanks to aftermarket steering wheel intall attempts gone wrong.! :)
lol,
steering wheels can be an absolute bitch, just keep trying it will come eventually. you can also get a friend to hold one side of the wheel, you hold the other side and pull hard. sometimes, bashing it side to side really quickly from the front with your fists helps to loosen it.
you can buy steering wheel pullers, but you should be able to get it with some time and effort. It took me 20 minutes to remove a steering wheel one time.....
Shaun I found success by rocking it back and forth from left to right.
Pull hard from the left, then pull hard from the right. Rinse and repeat. You'll end up walking it back towards you and then BAM! you'll be glad you listened to Beer Baron so you don't look like poor Sumo :)
    • @GTSBoy Yeah i know. The RB20 has 180Nm torque and the gearbox "should" take up to 400Nm if you are not doing stuff like drag/drift or dumping clutch and of course then it is pure "luck" on how will it last. My problem is (i think i said this in different post) that my car was very badly maintain so i would not be suprised if the oil in the gearbox was not changed until i bought it. Yeah the gearbox seem little bit sad.   @Sxnjeet the +T seem very interesting but from where iam from it was nearly "impossible" to done right and not blow twice as money as just swap for the RB25.
    • Hi, I went to the MINES shop here and bought something.. Niikura-San just happened to be there so I managed to take some pics and got him to sign my dash surround thingy. Its still wrapped in plastic back home.. I was thinking how to preserve the signature??? Im sure someones thought of this and done this in the past.
    • Perfect - thanks Joshuaho96!  Will see what I can source.
    • If the plastic wore, the paint will wear quicker. Heck, most car manufacturers cant keep the coatings they put on their buttons/trims alive these days for more than 5 years... A cheap paint won't do it!   However, you can get away with high quality vynil wrap, primarily in areas that won't cop much abuse. Skip colour matching, and just try and wrap a specific area with an edge in a new colour.   PS vynil wrapping is a prick of a job, and I suck at it, even for a small dead flat surface...
    • I think this is more a question you should ask the tuner. My assumption is you have nothing plugged into the original pin for ring gear crankshaft, which is where your map sensor should get wired to, but now you've asked the tuner to disable it. I'm assuming (because I haven't memorised your setup) you are using RB25 ECU on the RB20 loom, to plug into an RB25. You will want to check what else is connected potentially backwards between the engine, loom, and ECU. You might be all fine and safe. The best solution you could have done is wire in a map sensor, and leave the ECU able to read a map sensor.
