This is the first 100+ Octane (Shell claim is 101) fuel available at the pump. It's not much more expensive than V-Power (Optimax), so what do people think?
Info on it and locations here:
http://www.shell.com.au/vpower-racing/
I filled the Lancer on Sat for $63 and have so far done about 260km on half a tank. This was a bit of freeway, bit of stop-start and a bit of zipping around through the hills. To compare - coming home from Sydney (all freeway) I managed 430km on a tank of Mobil 8000. Can't really tell about power delivery as I'm still not used to the car - but it's certainly not sluggish - so VPR looking good for me.
Steve McQueen is using it in the bullet and notes a bit smoother power delivery (even with a few degrees more timing) and reasonable economy.
Anyone else run more than a tank?
Thoughts?
J
https://www.sau.com.au/forums/topic/141172-shell-v-power-racing/
  • Replies 54
checked it, doesnt recommend that I use it for my 96 gtst - so I havent. But my friend used it in his 06 accord euro, and says that he feels the response is so much better. He is still testing to see how many k's to the ltr it does.
^^^ You have to be careful if you're using it in a modified car with some sort of aftermarket tune in it as the ethanol content can vary your mixtures.
Personally I haven't used it as yet, but I've been meaning to try it, so maybe next fill.
On my third tank...
i usualy get around 300kms on BP ultimate. I am getting 320kms on VPR... But my custom tune which was originally for BP 98 is working much better on VPR. Heaps more mid-range from my seat-o-pants meter.
Only thing I have noticed is at high RPM in 4th gear the car is tapering boost out earlier...
must try this, but the locator shows the closest station to me is Millpark, might have to run the weapon dry and fill up before a country cruise/thrash.
I have used Boost 98 which has an ethanol content but it seems down on power. Mobil 8000 is my choice atm.
Who is Steve McQueen and what does he do? (Im talking about the alleged real Steve McQueen not Brisby) :) hehe
I use it in my car and it runs really well, Ben from Race Pace insists it is the only fuel i should run my car on after he tuned it.
When the new engine is in I'll be getting a map made up for this fuel, aswell as 98. I still feel it's not readily available enough to have it as my sole fuel. I have heard of really good gains though when tuned for it.
As discussed with a Drunken Mr President on Saturday night, i have never heard of Steve McQueen or seen any of those movies as far as I remember (I do have a shocking memory though), thats why i posted that original post in this thread it was more of an in joke I suppose.
It is also why James is apparently giving me the important Steve McQueen Movies for christmas, he'll probably just steal them from Brisby! :whistling:
V-Power replaces Optimax and is available at most Shell servos
V-Power Racing replaces Optimax extreme and is located at only a select few Shell servos. The website says its actually beter than Extreme was with a minimum of 101 octane and often more than that. Maybe that is a good reason not to tune specificly to it?
Edited by FINER6
    • Unless you have big cams, there is no reason for an RB to idle at any more than the stock 650. No, it is not 850, 950, or anything else. It is 650. In fact, it might even be 550. I just opened an arbitrary stock Neo file in Nistune, and this is what I see
    • I love the undertray, especially the flappy bit for easier access for serving I'm thinking of fabing up one at work for the MX5 while I still have access to the metal shop at work with a guillotine and press brake Whilst removing the plastic undertray on the MX5 isn't to hard, I love the idea of a 2 bolt flap as opposed to removing the whole thing
    • Great thank you for that. Yeah that is the bumper and spoiler it still has i just hadn't heard of it being referred to as a aero form bumper before. Really appreciate your help.
    • A little progress; I took the opportunity of an oil change to take a sample for oil analysis, will be interesting to see how it was treated for its first 125,000klm (I know how it has been treated since :rofl:) I went with 5w40 and will see what that does for oil pressure at higher revs. Also fitted the Z1 front undertray....a little more sturdy than the plastic factory one (although I suspect it won't stop a tree stump ) Nicest thing about it really is the 2 bolt "service panel"....a gift to the oil changer compared to removing 14 bolts holding the factory tray.
    • I think a scissor lift is better/faster in most cases, but I guess it does obstruct access to the centre of the car? BTW I weighed the quick jack. 3.5 tonne model is 50kg for each side. So yes, portable, but not with one finger
