  • Replies 353
Posted Images
8 pages long now... I think the answer to the question "custom stainless exhausts, interest?" is a massive "YES!!!"... how about we keep on topic and in this thread and maybe make this a sticky in the for sale section?
just my 2c as this thread will probably continue... which a testiment to Marks work... good luck with the new workshop mate :thumbsup:
i was muckin around the other day with my mate and disconected my cannon and god damn did my car sound nice, had a really nice roar to it i was thinkin is there anyway possible my cannon could be cut off and mayb u could make up a bit of stainless 3 pipe and weld it on lol ? sounds stupid i know but i mean when the cannon was disconected it actually sounded like a performance car
sam
hey sammie
that would be no problem at all , just let me know when you want it done.
kermit
hey this sounds like an idea
accept my muffler is welded to my exhaust piping, the next set of flanges are were it joins to the cat *sigh*
so my question is can you make a cut after the muffler and put some flanges on to and also have a piece of pipe put in there to eliminate the muffler, i want to be able to interchange between strait through pipe and muffler......if that makes sense lol
regards
the other Sam :)
regards
the other Sam
copy !!!!!!!!!!!!!!!!! jst kiddin hha would be goodtho if he can make somthign up like that.
regards
the cooler sam
Currently mark aka kermit is working on my rb20 180 here some pics of the cooler piping in the process of been made...
also like to note that mark currently is having pc issues which are been fixed should be getting back online soon
here is a link to some pics of what the work been done *note all taking with a camera phone*
http://mrlags.blogspot.com/
regards
the other Sam
regards
the cooler sam
hey guys ,
tis easy peasy lemon squeasy ,
just gimme a shout
kermit
just a question will the weld marks on the exhaust rust out after a while?
no the welds on the exhaust will not rust out . eventually they will oxidise ( easily cleaned off surface )a little ( am talking many years ) but they will never rust. thats why people use stainless instead of mild steel. i always source good quality stainless materials and filler rod , not low quality china spec stainless steel .
i am always disgusted when i see stainless products which are rusting . thats why i hate china products.
kermit
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
