  • Replies 353
Posted Images
i thought u get a massive fine for having an exhaust without a cat?
but i would like a bloody curdling exhaust :ninja:
if you dont have a cat dont you get a yukky petrol smell when you are driving, i think i read sumthin along those on these forums sumwere lol
you only get a fine in all the other states. here you get sent over the pits and they will tell you to fit a cat. if i get stickered i will just refit it. i build my cat replacement pipes to be a straight replacement for the cat so changing them over is a 5 minute job. i dont get any strange smells either although you may get a little discolouration of your rear bar around the muffler.
i have a 3 " straight through cannon style muffler , no cat and 3 " straight through front pipe and catback . havnt found another which sounds quite like mine . can replicate the cat back if you like the sound for $800 fitted inc muffler
kermit
kermit
well ive got the twin 3 inch front pipes that merge into a 4 inch collector that goes into my MetalCat, then 3 inch all the way to a quiet kakimoto, so all id need replacing is the muffler. What mufflers (cannons) do you use??
to be honest i cannot remember which brand it was (nothing flash to be honest ) but i do remember where i got it so i can source more plus they only cost a couple of hundred bucks.
as soon as my car is running well ( my guru is hopefully fixed it already) again i will be making myself known at cruises . so i guess you can hear it in the flesh.
kermit
kermit
sounds good, let me know when youre up and running
what diametre pipe is it? does it require silicon hose? a rough quote would be about $120 fitted and polished but it does depend on the diametre.
kermit
what sort of cost would it be for an intake pipe for a hyundai excel ( :D )
bout 700mm long with one 45 degree bend
Krammmitttttt once my engine is fitted and gets retuned, I'll need you to knock me up a new straight pipe with muffler.
I'll see you before then anyway more than likely!
Why is GTR for sale :( Surely Vin won't be happy, as neither will u :) Going to miss that EVIL machine
hey mate. sorry but i wont copy stock parts this way. the only way i would do it is to have the car and build to suit . one tiny difference means that it wont fit and then my reputation is gone.
kermit
i need dumps and front for a r33 gtr . no fitting . could supply the stock ones if you need them to make up new ones while the turbos are off . 3in stainless
Guest
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
