easy peasy . as you are suppling the cat . does it come with flanges or do you need them welded on? will remove old one and refit new one with flanges and fit to car for $100 or $120 if i have to modify cat to fit
kermit
I'll need someone to fit my cat when it arrives...if it ever arrives :)
  • Replies 353
Posted Images
Cool Kermit :)
I was told the car doesn't have a cat, whether its there but empty or gone altogether.. and please don't ask me to check cause I wont know what I'm looking at hahaha :) Oh and its coming without flanges, that much I do know :(
I'll Pm you when it arrives :wave:
tis a full day job but if everything is supplied then i will happily do it for $200
kermit
0422549050 can do when ever , during the week is prefered
gtst, sorry i just meant fitting though :) i have the kit already :( just dont trust myself to chop up my front bar.
kermit
awesome, wikkid price, will DEFINITELY be booking this as soon as i know the rest of my schedule. probably be next week though
- Hey everyone.
I just got my car back from Kermit today.
He fitted/modded an exhaust I purchased from ebay to fit my R32 GTR - with a 3 inch hi-flo cat I purchased locally. He custom fitted some flanges to fit the job etc.
I must say, the job was well done, although it took a bit of extra work (by fault of the car) - the fit/finish was a top job all done in a respected time.
Kermit : it sounds 10 times better now, I can actually hear the turbo spool up now - and no - unwanted backfire :O It pulls better etc than before!
I thoroughly recommend the work of Kermit 100% - feel free to PM me for more information.
oh yeah - and Kermit's GTR - is tidy as! - and goes hard :O
All you would have to do is put it back in , they would just give you a yellow sticker and you would put it back before you go over. i wouldnt reccommend it but then again i wouldnt recommend smoking either....
kermit
kermit u wouldnt recomend a cat replacement for astreetu used car correct ? just found out the fines involved if caught? just wanted to make my car sound meaner realy quiet atm
oh u can put it back in easy ? i thought it was a welded piece, well once i get my turbo and new engine mods in i wont be driving it much at all most likeyl weekends only, il be getting another car within the next month or so, i might consider it if its eay to take off and on
would cops often check under the car for a cat ? or mainly the carbon build up on the rear ?
i dont have a cat and i get no carbon build up on my rear bumper and the cars white! but i also do wash my car often soo maby thats why.. soo if you take care of your car you'll be right..
as for cops getting under your car well i HIGHLY doubt it.. its only the pits guys that will spot it
i have a carbon build up but im too lazy to polish it off ( im too hard core ). cops have never looked under my car even when i get pulled for being noisy. takes couple of hours to make , depends on rusty nuts and bolts etc and if cat sensor is seized as i refuse to cut it off ( cut it out instead then it is at least still there just not used).
kermit
Guest
    • What could be causing my clutch problem besides a bad master or slave then? Both those parts are new
    • Just came across this, but in QLD I start leave again in 2 weeks, if it is still available I might drive up and check it out Unless, @MBS206 do you live near here????, if so I could hit you up with a finders fee https://www.gumtree.com.au/s-ad/hope-island/auto-body-parts/nc-mx5-factory-hard-top/1328976391
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
