Hey guys,
Got some spare parts of my 94 S1 R33 Gtst which have just come off the car! Live in Hobart, Tasmania!!!! so i can send them if buyer pays postage!
I have the following
1 x Stock R33 Turbo 65,000km minimal shaft movement $350ono..........SOLD
1 x Stock R33 Manifold, good condition $150ono
1 x Stock Set of R33 Camshafts, good condition $200ono
6 x Stock Injectors, unsure of condition (will ask mechanic) $150ono
1 x Stock AFM, unsure of condition but was working ok & pfc said it was fine $50 ..........SOLD
1 x Stock ECU $150ono
1 x Custom built Stainless steel Split Dump/Front pipe from Advan, very good condition $350..........SOLD
1 x Stock Cross over pipe with stock BOV, good condition $75ono
1 x All pipe work on the Turbo side to suit stock turbo, $125ono
1 x Stock Ex. Cam gear, good condition $25
1 x Stock Suspension with Lowered Springs, good condition worked fine $250ono
1 x Whiteline Adj Rear Upper Control Arm Kit (New) cost $300+ will sell for $225ono
2 x Federal Tyres 75% tred 18/235/40 $100
Probably have a couple more parts as well but I will have all these parts buy the end of the week! Buy the way I am negotiable on parts to an extent & would prefer to sell them locally or else the buyer will have to pay for freight!!
Might be able to put some pics up if I get time!
Pm me if interested
Cheers
Alan
Edited by al_r33
https://www.sau.com.au/forums/topic/141202-parts-for-sale/
Cheers Leigh,
tridentt150v,
The Dump pipe is the exact same as this one!
Musky,
I don’t have time to Organise freight! But if you can then I would be more than happy to drop them off!
Cheers
Alan
Edited by al_r33
https://www.sau.com.au/forums/topic/141202-parts-for-sale/#findComment-2630213
  • 4 years later...
    • The more I think about it, the more I should probably go with a genuine Bride seat and rail set up. But damn the $$$ for a driver and passenger seat + rails!
    • From what I understand, stock internals should hold out for a while even if you run 500 at the crank, no? Especially if you don't run a modern turbo setup that reaches power and torque much earlier than the original twins. My engine isn't unopened either, it has N1 Pumps, head oil restrictor, new crank and cams, new piston rings, ARP head studs and Cometic headgasket along with 2860-5s. Considering everything is healthy this should run fine for a while I assume. Once my engine stops leaking shit everywhere, it'll be tuned to 370 crank first anyway, because I need to legalize the turbo setup. If I end up needing a new engine because my block actually has an issue, even though GTSboy was adamant that the whole porous block story is nonsense, before putting an engine in I'm probably gonna take care of the weakspots.
    • Hah, I have no issues with what you are doing whatsoever! You clearly know what you are getting yourself into. It's just funny reading things like this. "What's that noise?" "Oh, that's normal. That's just the engine not getting any oil. Nothing to worry about. It'll go away in a moment"
    • Yeah I'm keeping an eye on it and might take it out as a once off if this doesn't fully charge. I did some research that said it's normal in equalisation charging. Voltage I thought was 20+ (faulty battery in multimeter) but now its on 15.9v, the max it should go to is 16.2v as per the manual. I'll provide an update once hopefully it's actually fully charged and in float mode. Waiting for it to go to 16.2v and not higher and see what happens. What I suspect has happened is that even though it's not an old battery, I did leave the car turned off for almost 4 weeks at one point then left it off for another 2 weeks which might have erroded the battery and is taking a long time to do this equlisation charge.
    • I wouldn't be using the seats a lot since it's on Historic rego and will not be driven a lot, however I also don't want to fork out 3k for something that won't last. Havent looked at BRZ seats, aiming for something of the same era I did speak to him on the phone once, and I do see your point haha. How many kms do you think you drove before they started wearing out? Just had a look at yours, certainly looking for a reclinable version. The Brides don't look too bad! I would still like to sit in one just to make sure it's what I'm after.    Thanks for the replies fellas.
