Hey Guys,
I've spent the last 2 hours searching and can't find it.
Can anyone link me or;
1) tell me the differences between the R33 turbos.
2) Which one is best suited to the RB20.
3) I know you need to make sure you get "the elbow" for the conversion...but what is it? What does it look like?
4) Any other things I should do first? Fuel pump perhaps? Will I need a SAFC or similar aswell?
Cheers
Chris
Edited by eXc
Hey,
Get the R34 Turbo!
I have a R34 Turbo on my RB20 and it runs really well! Bolted straight on and used the RB20 Actuator to get the stock 10psi. Boost starts just before 3000revs and Full boost comes on just before 4000revs. :D
Edited by r32matt
1. i dunno but i would like to find out. i recently just too my S1 turbo off and replaced it with an S2 (because the S1 was rooted) and noticed that the design of the compressor wheel was a little different. the smaller blades did not protrude past the tip of the bigger blades.
and the S1 has a steel compressor where as the S2 has a nylon compressor
2. the S2 is supposed to spool faster due to the lower rotational mass, and seeing as rb20s cant spool turbos well, this would be better.
3. the elbow is the compressor outlet. go have a look at your turbo, it is the first pipe that comes off of your turbo, and goes into your intercooler piping
4. fuel pump is definitely a good idea, and you really should do it, just in case. another good bang for buck mod is to get your ECU remapped. cheap and just as effective as stand alone ECUs. and come with all the stock knock sensors, cold start crap etc
The r34 turbo, is pretty laggy i think (has the same sized exhaust wheel as the vg30). In first it doesnt start spooling to about 3-3.5k so it makes taking off sort of hard, it does kick in hard at about 4.5k though. The performance increase wasn't all that great for me, i got a remap at the same time and achieved only 164 rwkw (on the same dyno, that i had had it measured, close to stock, at 133rwkw)
i will upgrade to cgc hi flowed series 2 r33 turbo soonish
Unless i get off my P's before then, and can get a GTR
S1 is definitely still worth it
easy to tell the different compressors, one is aluminium and the other is nylon. they feel much different
and the number on the comp cover is different
i think the S2 has 45v4 and S1 has 45v3
may need someone to confirm, thats just going by my crappy memory :D
Edited by salad
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
