My Intro
prego
 Share
  • Replies 40
oooooooo hellloooooooooo Nathan and how are you today.
So ya going to get a r32 ay cant go wrog there good power for ya first turbo car and when ya get good at driveing it ya can get a engine up grade. RB25DET/RB25DET NEO or the bigg daddy GTR RB26DETT oooooo yerrrrrrrr. Me i got the neo but any ways have fun and be safe
yeah but already discussing mods for the most power with my buddy damo
ill have around 3000 for mods if i want to spen that (which i want to :P )
atm im looking at a n14 model TI (2.0L version :D)
manual 92-93
Edited by prego
 Share
    • Thanks mate, yeah I've heard that alot and i am definitely regretting using the 25 Loom now, i have gone through and traced all the plugs from the 20loom and re wired them into the 25 loom, I have currently got Crank, Fuel and accessory's working, just need to finalise the loom and run the wire for the Ignition (Spark) and it should be running, will update if i have any luck.
    • Cheers lad, when I head over there I'll give it a shot.
    • Stock less likely to carry one like that than urethane, but still can, especially if the bolts are not as tight as they should be. If it's making that much noise you should be able to use a hose as a stethoscope> stick one end in your ear, crouch down and wave it around the various possible noise makers and get someone to lift the front end at the guard lip.
    • Broken actuator rod. Could be one of a couple of them broken. Or, it's locked and the central locking actuator is broken/stuck or the actuator rods between it, the lock and the key barrel are jammed or broken similarly. You'll probably need a locksmith/mechanic who is experienced with using slim tools to reach down next to the window glass to manipulate the mechanism. That's assuming that it is not so severely jammed/broken that nothing useful will move.
    • So I've got my R34 GTT it's currently in Japan and I'm not there. I was wondering if any has any tips or ideas of what could be preventing the door from opening. I dont have really any information on it at all since I haven't actually seen the car in person yet.
