hey guys just wondering on your opinions for the best thing to do bout my car, i have light mods so far and i reccently bought gtr injectors + resistor pack to suit my rb20 r32, i was thinkin of installin a pfc + retune but due to the overall cost of such an excersize, i was after your opinion on runnin just a fuel controller to run the injectors and manage the airflow, my question is, how good will it run? i realise its not gona be as good as a pfc but for the price/hp gain, would it make it better on fuel? more power etc etc. honest opinions please as im not very knowledgeable on such a subject.. thanks
https://www.sau.com.au/forums/topic/141279-safc-ii/
here are your options
1) buy ap engineering PFC
$1400 + $400 tuned
- expensive ap engineering version
- option of power fc pro for same price
- can be tuned / fixed by anyone who supports PFC
2) buy rb25 or rb26 PFC
$950 + $400 tuned
- rb25 version should throw errors for VCT sensor/trigger
- rb26 version can support twin afms if u want later on
- will need rb26 injectors for rb26 version
- may not work correctly if done wrong
3) buy a remap for stock ecu
$450 ish tuned
- cheapest first off
- will be $450 to have it fixed or "tuned" again if you change stuff later
- locked into only people who can remapping
4) safc II
$400 to buy it (ish)
$250 maybe to tune it?
- cheaper again
- has limited load points and tuning capability
- wont support bigger injectors
- will push the stock ecu too far in the end, the more u lean out or bend the afm signal, the more timing it throws in, so youll eventually be stuck, but it will be fine for stock turbo
- cool display screen
they all should make the same power and performance
the main quality will be how good the tune thats put on the stock remap or PFC. if the PFC tune isnt that good drive to another PFC tuner and get them to touch it up, or use the PFC FAQ and do some of it yourself. you also get a lot more visiblity with the PFC over the stock remap. you get knock sensor notification, afm support, injector support, airflow warning, injector warning, sensor display, 02 sensor feedback and hand controller (also option of pro version if ap engineering). if the remap tune sucks u have to goto the same person or only a few select remappers and they will just charge u the same price most likely to touch it up each time, as they just burn the chip again. PFC touchups should be much cheaper and quicker
www.nengun.com
4E14N07Z -=> AU $ 1,452.91 - Apexi PoweFC Pro - Nissan Skyline HCR32 RB20DET (H/C 415-N001 Included)
4E14N07Z -=> AU $ 1,373.63 - Apexi PowerFC - Nissan HCR32 RB20DET 89/5-93/8
414-AN012 -=> AU $ 908.71 - Apexi PowerFC - Nissan Skyline ECR33 RB25DET (For Version 1&2)
414-AN029 -=> AU $ 908.71 - Apexi PowerFC - To suit BNR32/BCNR33
those prices are delivered from japan but don't include customs, which it is meant to be exempt from
https://www.sau.com.au/forums/topic/141279-safc-ii/#findComment-2631454
i would suggest powerfc as your best option (rb25det but do some research on what you have to do to get it to work).
unless you live somewhere where there is a good remap tuner (hard to find)
think of it as a long-term solution, do you ever think you'll buy an aftermarket turbo? how much power will you eventually be aiming for? if your answer is "yes" and "more than 160-170kw" then a proper tune is a must....
https://www.sau.com.au/forums/topic/141279-safc-ii/#findComment-2631803
i guess it also comes down to who tunes it and how good they are
if its just some kid with an eprom burner who dumps a map on and off you go its not going to be as good as a well done PFC tune. by "good" or "well done" i mean the number of load points adjustmeted on the piggyback or remap or PFC tune. the more points adjusted the better the car will be to drive. a stock PFC on stock maps is good but an safc with all the load points tuned will be better. likewise with a PFC with say 30 to 40 points adjusted it will be ace to drive around and have much better response, and probably average power. likewise with the remap, if its got a big wad of ign and inj points adjusted it would be better
https://www.sau.com.au/forums/topic/141279-safc-ii/#findComment-2631973
the number of load points adjusted isn't a very good indication of the quality of the tune.
the quality of the tune would be a function of...
1. the comprehensiveness of the tune (relates to number of map points adjusted, and also relates to the time spent tuning under different conditions)
2. the tuner's skill
3. the features of the ECU
i'm going to avoid talking about remaps v powerfc because it's been done to death and we won't reach a meaningful conclusion
but i will say this:
If tuner skill is equal, a fuel only computer will give you a much poorer tune than a fuel and timing computer (or remapping fuel and timing maps). Tuning a fuel only computer is very very easy, if you have the right tools, it's a simple logical process with little-no guesswork.
1 and 2 are the most important factors, and provided an aftermarket ecu gives you a reasonable level of adjustment they all have the potential to provide equally good tunes. Remaps and most of the aftermarket fuel and timing computers people are using all offer similar features and level's of adjustment.
Edited by MerlinTheHapyPig
https://www.sau.com.au/forums/topic/141279-safc-ii/#findComment-2634362
    • He is around but doesn’t really do automotive stuff anymore, mainly does commercial work now
    • Shortly after I do the usual full exhaust/ fmic/fuel pump/ R33 turbo and still get flogged at the lights by i30Ns
    • Is Chris from Craved Coatings still around? He is an ex SAU guy and did great powder coating (back in the day at least)
    • Bumping this thread yet again, has anyone ever tried putting yet another vacuum regulating valve on the hose that goes between the turbo inlet? Something local owners have mentioned is the Radium breather pipes de-restrict the valve cover but it actually produces an undesirable outcome in practice, way too much air is sucked out of the crankcase and a ton of oil comes with it as well. As far as I can tell the PCV diaphragm in these modern euro wet sump performance engines is active during boost as well, there's just a check valve to block boost from entering the valve cover and crankcase as there's no inherent check valve function in these diaphragm-type valves. Hopefully I'll be able to try some of this out soon. The Volvo XC90 4.4 V8 has a nice external version of these things.
    • So when will the Samsonas, twin scroll turbo setup on go?
