hey guys how do i make a animated gif out of a few pics. i wanna combine the user bar thingys in my sig into one that cycles thru them. im lazy so im gonna ask if some one can plz do it 4 me. otherwise a how to or a point in da rite direction wud be nice.
thanx in advance
Edited by Basti
https://www.sau.com.au/forums/topic/141308-making-gifs/
  • 1 month later...
  • 1 month later...
Theres better ones then that.. as you can see it lowers the image quality.
I made my own userbars, but then imageready was being a c**t, so i had to use http://www.signaturebar.com/
to animate, ya dont loose ya image quality
Edited by rSrkt_
https://www.sau.com.au/forums/topic/141308-making-gifs/#findComment-2836155
