I had a weird experience on my ER34 yesterday night.
While waiting at the lights, the electronics went dead. Headlights (taillight too I suppose), meter lights and the audio unit. It went dead for a second or two but the engine is still running.
Afterwhich, everything gained back power and as per normal. My check engine and fasten seatbelt warning lights remain lighted for about 5 secs before turning off.
This is really weird and worrisome. Am afraid that suddenly while driving everything went dead on me.
The above happened twice yesterday nite. :yes:
https://www.sau.com.au/forums/topic/141336-electrical-fault-in-the-er34/
The above happened twice yesterday nite. :happy:
I can only suggest your battery terminals , remove both & give a good clean with wire brush & the battery posts. Ck your -ve earth lead from the battery to body mount point is secure , another cause could be your voltage regulator which is inside the back of the alternator, can be replaced separately though. Have you washed down your engine bay lately- could be water in the main wiring loom/box area???? Good Luck....
Just some update. Today more weird stuff happened.
1) On the way to work this morning. The speakers went dead. My headunit is still playing but there are no power to the amp and thus no sound from the speakers. Have yet to determined whether the amp is fried or the fuse is blown.
2) During noon time, similar thing as the above happened BUT this time the engine went dead. The first time, I'm idling at the lights and everything shut itself down. Give the car a crank and it restarted. Later it went dead again and I can't crank. Pop the hood and fiddle with the - terminal and are able to restart it.
Am dead worried that the engine will go dead while I'm driving on the road.
Anyway, just took a look at the terminal. With the engine on, I removed the - terminal. Engine still runs. Does that mean my alternator is a-ok and are charging as per normal?
I cleaned the - terminal and tighten back both the + and - termimal and hope all is well.
colgf, nope I did not wash the engine bay.
Dont remove you battery terminals whilst your car is running - you have a posibility that your voltage may spike to 17-18 volts and blow something up.
An Alternator will not cause the problem you are describing. Its more likely to be a power supply issue. Check your main power going into your fuse distrobution block.
There is a possiblity that one cell in your battery may be playing up with a fracture in it. Your problem is not common, and is hard to diagnose over the net.
Cheers
Sumo
It happened once in my car, driving along, come to a set of lights, the car was about to stall, and then it did. Started it up fine and drove again.
I went home and just as I got in the driveway it did it again, and then it was like the battery went dead.
Upon closer inspection looked like the stereo system had a short somewhere or was using a fault amplifier fuse or something (those big ones). Put in a new one and havent had a problem since. I also noticed that the power supply to the alarm wasnt connected tightly so maybe when the alarm detected power issues it just immobilised the car?
Ok the speakers went dead issue is partly solved. Think my amp has some problems and it was sent for repair already.
BUT
on the car going dead issue. It's still around. Some times, the electricals flicker a bit and came back alive. Just now as an experiment, I flash a couple of times, and the car seem to be drained of power. Everything went dead and flicker about. With the flash pro-longed, the engine went dead.
I had to give the battery terminals a knock to be able to restart back the car. After restarting, I did the flash trick again and there's no difference.
Damn what the f- - k is wrong with my car???
    • Thanks heaps Duncan and GTSBoy. I'll get my old man to sit in the driver's seat and turn it on and off while I test with the meter. Or maybe other way round, depending on whether he remembers where his glasses got to
    • This is the GTR fuel pump. Yellow shows 12V, orange shows earth. The ECU provides the earth to activate the fuel pump relay. The ECU side of teh relay will pull low when the ECU activates. This is the RB20 fuel pump. Almost the same, but a little simpler. You can see I indicated (above) where the 12V line goes down to the RB20 diagram on the overall diagram, whch shows both RB26 and RB20. This is where I show it coming in on the RB20 diagram below. You can see that the dropping resistor is handled differently. When the fuel pump control is not providing earth to the pump, the pump earths through the dropping resistor and thus runs at lower voltage (some is wasted over the resistor) and runs slower. I showed that "not 12V and not quite earth" portion of the wiring in a paler orange. The rest of the wiring that I did not colour on that little section below the pump would be orange when the fuel pump coontroller is providing earth. This drop is handled inside the fuel pump controller in the GTR. Regardless, you can see where 12V is supposed to be, where earth is supposed to be. The key on prime is via the ECU providing the pump for only a few seconds the switching off. You should be able to see that happen.
    • Yeah so when you turn key to IGN the fuel pump should run for a few seconds. If you find the fuel pump relay (and have a multimeter, and a second person) to can check the relay inputs.  One trigger pin should be either fully earthed  The other trigger pin should get 12v from the ECU for say 3 seconds when you turn key to IGN, and at all times that key is at START (note, I said this from memory, it may be the other way around, ie one pin always has IGN 12v and the earth has continuity to earth when you turn the key) One Pin should have a good battery voltage The last pin goes to the fuel pump + Also note that if the power to the relay is good, and the relay is working, it is worth checking the pump has a good earth too. There is a computer in the standard system that increases the earth resistance to slow down the pump when not required, pretty old school and it may have failed
    • All this talk about fuel and fancy ECUs, meanwhile my poor old R32 has neither.... When the ignition is turned on, should there be power running o the fuel pump constantly or just for the few seconds it usually takes to prime the pump? About to go have another look at it, have watched some YouTube vids on how to use a  multimeter and looked at some wiring diagrams but really have NFI what I'm looking for because electricity is invisible
    • Yuh....but weren't all the supertourers, except maybe the Audis, FWD? I don't recall any of the others being AWD.
