radar detectors - whats good?
Well i got a Beltronics Vector LR Remote Beltronics... Cost me $800.00 from strathfield (housemate works there so i got a good price) and it works really well... It usually picks them up about 300 metres away depending on factors like cars in front, if its on a hill, bends in road, stuff like that... So far i haven't got a ticket in the Skyline :innocent: Touch wood... :bonk:
Woody.
The multinova's work on the Ka frequency and the radars on the side of the cop cars use the K frequency... I've found that as soon as i hear the Ka frequency go off i instantly jump on the brakes and look for the multinova... The K frequency is used quite often around perth in the automatic sliding door sensors and some alarms will set it off... So sometimes its hard to find the cop cars with the radars hanging off the side... The detectors usually have the same features, but make sure it has K and Ka bands...
Sorry about the grammer, been at work since 8am and don't finish till 9:30pm so my brain has melted...
i got a whistler which is made by bel. it is very simplistic and is good for hand guns and multinovas, but best for handguns as it always picks them, up i noticed for the 1 year i used it in my gsr that i never saw a multinova on my side of the road LOL
i havent used it for over a year now. I think after the 6points and $350 fine i might start again cos that was a hand held. doh
it was $400 when i bought it, but they are like $330 now
THEY ARE DEFINATELY IN NO WAY AS GOOD AS THE ONE MENTIONED ABOVE AS THEY ARE HARDCORE, this one just helps heaps,
I have a BEL 980, has saved me lots of money and points, I've only had one speeding ticket in over a year ans that was because the cop car was off the my left in a side street and pinged me at such an angle that the detector didn't see him.
Cost me $800 from Audiocom in Freo. I thoroughly recommend this model. Picks up X, K and Ka, has City and Highway modes, even a vioce model where it will tell you the Band that it has picked up in an American accent instead of just a particular noise.
you gotta spend money on these things- I got a Bell 850.
I found the major problem with detectors is falsing- going off when there is no radar around- no alarm is any good if it falses- boy who cried wolf. As expensive as mine is it still falses on K band- therefore I have turned K off (at least thi model has this feature) K is only used on the cruisers so until I go out bush or hit serious freeway time I should be OK.
Warning time varies greatly- from 500m to 10m (impossible to slow down from some distances so the lesson is these things do not give you carte blanche to drive faster) depeding on many different factors.
Isn't K band also used for the handheld radar guns?
I wouldn't be game enough to turn K off in the city, sure you get a few false pings but you get to learn the difference between an automatic door and a real ping, the doors are usually quite weak and you learn where your likely to get these false pings, always in he same places etc.
It's better to be over cautious that risk the ticket IMHO.
EDIT: sorry, just remembered the handheld guns are lasers (which mine also picks up).
And yes you do get some variation in the warning distance due to the surroundings at the time and whether the camera operator has it turned off and waits for you to get close before arming it, not much you can do about that. Also, you get a warning for the laser guns if they are targeting someone infront of you for example but if they are pointing it right at you then the warning is them getting your speed usually :D
i got a cobra radar detector its pretty good but same problem i catch to many interferance but that something that you will have to put up with eg. service station, taxi's i got k, ka, vg, x and a few more gets a bit annoying after a long drive but it has saved me a few times and i found that its a bit cheaper then the rest. I purchased mine when i was overseas and it was really cheap $100us so if you know someone it would be a good idea, ive also noticed them being on ebay brand new type in radar detector.
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
