2 Items here for sale.
- Standard coil packs (x6). Still in very good working condition. Removed them as i replaced them with Splitfires. $150ono. pics at: http://www.users.on.net/~ula/CarSale/
- Original BNR34 rims. (18x9). Currently has Nankang NS-II's 285/35/18" all round at approx 80% tread. Comes with the original centre caps. Some gutter rash. Prefer Melbourne buyers. Can separate the rubber for a cheaper price if needed. $2500ono. Pics of wheels are @ http://www.users.on.net/~ula/WheelSale
Edited by uLa32
https://www.sau.com.au/forums/topic/141375-melb-bnr32-parts-for-sale/
Some pics...
Before and after shots of the King Springs.
Part numbers are: KDFL-101(F), KDRL-102®
Further pics are here: http://users.on.net/~ula/Sale/
3 Bilsteins are only available as one of them has snapped shaft up the top. Buyer can have it if they want.
Condition on above Bilstiens is unknown but not leaking.
Edited by uLa32
  • 3 weeks later...
bump.
parts still for sale!
King springs: KDFL-101 (Fronts) will fit Skylines R32, R33 and R34
KDRL-102 (Rears) Fits the R32 only
Kings springs catalogue available here: http://www.kingsprings.com.au/kings_master_catalogue.pdf for verification. Page 17.
  • 1 month later...
  • 1 month later...
bump...
taking backups of all the above as well. Parts will be binned early next week!
Pics are with old rubber (original RE-01's) but rims are still in the same condition.
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
