i would agree with no respect! response has a great 4 chan amp for about $400....
i would run the fronts off the amp, rears off the head unit and bridge the 2 channels left for the sub...get a half decent sub, and you will have a good quality sounding system
(upgade the battery will be wise...skylines always have dodgy batteries!)
NO_RSPECT is correct.
for $400 u wont get shit in big name brands.
jaycar makes good amps and their cheap, but ppl think eeewww its a jaycar its gotta be shit.
for $400 to run 4 speakers is pretty hard.
i got a v12 cost $900 jsut to run my front splits.
o it has sub output but thats just shit.
You should be able to get a decent amp for $400 - If you want comp grade stuff and make lots of noise then of course you have to pay for it. Its only if you hear the really good stuff will you want it :D You can always upgrade later down the track if you're not happy with the final result.
A good "mid range" amp you'll probably going to get good sound out of and you'll be happy with - its going to sound better than the face-unit amp at least. Just don't get anything too bargain basement ($250 for a 4 channel) because i have heard people try to go too low grade and they sound shit.. hissing, other noise, lack of clarity, everything. Its not good! If you've got reasonable speakers than it seems a waste to destroy the final result by a very poor amp.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
