  • Replies 62
fark. Thats pretty bad luck. Did the towtruck guy have a hard time getting you on the back of the tow truck?
I guess its a free lesson to everyone else here that has these kind of sh1t cast rims....get rid of them now :happy:
Na mate, no spacers.
That photo of the 33 is just so uncanny, almost the excact same. Compare the two photos.
Still can't balieve it happend. Not pissed off about it, but dissapointed.
The positive from the day is that had a mad time, and I never liked those rims anyway, see them all the time on wrx's, lancers, civic's etc. Time for some new ones.
To answer someones elses question, to get it on the tow truck was a ball breaker! the hassle to remove the nuts was wicked. Got to say the driver (can't recall his name) from "Benella towing" was a really nice guy, took the time to do every thing with out causing thurther damage, thanks mate!
Just a note for anyone here, if you know how to convert dvd into mpeg format then PM me and when I get it (the footage) and I'll upload it to vid section. As I said in my post, my mate was a passenger at the time and caught it on video, so I'll put the lap leading up to it on. My mate was telling me that two corners leading up to it, the camera was flashing flat battery, almost put it away but continued to record, just after the impact the camera went flat.
Having a spacer moves the pivot point out, hence making the torque loads higher on the hubs and stuff.
Ok, but it couldn't be that bad...right? I mean with proper bolt on jobs???
sorry to hi jack a little bit, how many of you track guys/girls have spacers fitted to the car?
ever had any problems directly associated with using spacers?
thanks,
Greg
thanks,
Greg
sounds like someones worried about their spacers...hehehe
Also, I wouldn't go rushing out to email Tempe, as there are countless versions of that rim. Avantek titanium is the main and more expensive version of them, but there are several other manufacturers that make the exact same design.
thanks,
Greg
I run spacers and haven't had a problem thus far... but I'm a little paranoid too now! Still gonna use them though
My top grade rims *cough were manufactured by Rossa.
Never herd of them my self.
As I said in my post, I wanted to change all four rims to stockies but could'nt remove the front two. Still wouldn't have expected what happend to happen, but can't cry over spilt milk as they say....
I reckon I went around that track 20 times and grinned like a little boy on Cristmas eve on every one of them. Just loved it.
    • Yeah since those first 2 replies I actually went and put some 98 in it and tbf it's already doing much better than the 95 (which is weird and makes my inner tinfoil hat wearer think the 95 was a crap batch), getting 8ish around town. Again, wonder if it takes a while to stabilize if the fuel is changed a couple of times. I swear cars used to just either run "well" or "s**t* in my 20s, none of this fuel optimisation business haha
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
