I am upgrading my injectors to low impedance/ hi flow on my R32GTST/RB20DET and I have a GTR resistor pack to be fitted. What I'm not sure of, is if the RB20DET has a stock resistor pack that needs to be removed/left alone? Does it have a resistor pack at all from stock??
I've noticed the small silver box mounted near the power steering reservoir, mounted on a bracket of it's own, with two wires down to a cannon plug. Looks very much like a resistor pack??
Can anyone identify this box??
Rgds, Grippy..
https://www.sau.com.au/forums/topic/141483-rb20det-resistor-pack/
im going through the same dramas with my RB25 conversion right now...
im so completely daft i cant quite figure it out.
as far as im aware, that silver box is not a resistor pack...
a resistor pack has 6 wires coming out of it, that silver box only has 2.
EDIT: I think we need someone who is very switched on (sydneykid) to write us a tech article...
Edited by andylaurel
Rgds, Grippy..
Lots of answers here
http://www.skylinesaustralia.com/forums/in...=62674&st=0
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
