you can go pretty hard setup on the rear suspension as long as the front is stockish.
Too stiff a setup at the front is what kills you. Too low as well.
Get the KCA349 kit from whiteline suspension for the rear diff cradle. I have this kit and otherwise the suspension is stock.
excessive camber causes excessive camber? that's a new one on me shuto boy.
as rev said though, hard at the back is okay as long as ur not too hard at the front. i know i know, it SOUNDS backwards but it's not, okay?
also, diff cradle kit is great little mod. on the camber issue though, if skylines are lowered properly, they dont have camber issues at all. (i.e. by properly i mean with appropriate adjustments/add ons to aid camber and castor adjustment).
My 0.02
dont want to go too off topic here, but seems that the neg camber on the rear, is a common thing when the car is lowered. i have tein coilovers and the car is a bit lower than stock, there is slight neg camber on the rear, which isn't helping for traction, and is also is chewing the inner tread of my tyres a lot quicker than the rest. what can you guys recommend, as the best way to fix this without wasting money, but gaining good results? cheers.
i have seen r33's with pod and full exhaust, that couldn't even crack into the 14's, because of wheelspin. main thing is tyres and suspension and the driver, a stocker should be able to pull a 14.2, i've seen it done.
i've got a 31 that weighs the same as a 33 (1400kg) and it has an RB25.
it has cooler/zorst/pod/ecu map (just a bit smoother) and a t04e running 9psi and i came away with a 13.85 and that was on Simex 215/60/16
It has around 190 at the wheels like a few other 33's with stock turbo's running 12-14 psi.
your mate should get at least a low 14 more to high 13... as he should have around 170-180 at the wheels. Power to the road is only a rough thing to go by.
rev210 has done better than i have and his is far more stock than mine.
It all comes down to how you get it off the line/60ft time. If it's up around 2.5 or about you can chop off .5 of a second with a good launch which in turn brings your half a second lower
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
